k20a3 (stock) vs. D17 (turbo)
Old Mar 12, 2005
  #61
civic01vtec's Avatar
Originally Posted by aznboysrfr
what's your point? ... if you're gonna compare a built 13 psi turbo d17 to a stock k20a3, that's ridiculous.
k20 > d17
i am still trying to figure out what your statement has to do with his quote
Old Mar 12, 2005
  #62
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Originally Posted by gsrchad
id say go turbo...
for a couple reasons...
1. say you run 8lbs and pull slightly on a k20 i/h/e.....
for you to go a little faster is a lot easier and cheaper than the k20... all you need to do is say lower compression and run 10-11lbs....
2. if something blows, its a lot cheaper again to fix yours.....
3. turbo is the greatest feeling in a car
4. and say you put downt the same hp as the k20, i believe you will have more torque so its not quite the same...
and i have 300+whp and i dont have traction issues...
well only in 1st and part of second...
so just spend a little on traction and your good to go....
1. he said he was gonna run 6 psi, not 8 psi. lowering compression is expensive ... ~$400-600 for good pistons + labor ... and if you get rods to go with it, even more expensive. does anyone even make aftermarket d17 rods?
lower compression pistons = less hp per psi ... imo, the price of lowering compression to 9.0:1 isn't worth it to only run 2-3 more psi (from 8 psi)
2. that is totally ridiculous. NOTHING is going to blow up with your k20 unless you misshift ... that's like saying that ep3's and dc5's have to be careful with blowing up their engine
3. that is an opinion, not a fact.
4. I don't even know what to say .... um ... cool?
here's a dyno of an ep3 with i/h/e/k100 ... 165 whp, 142 wtq
another dyno of an ep3 with i/h/e ... 163 whp, 137 wtq ... no hondata this time.
I believe the sf kit with their upgraded turbo put down 166 whp, 16x wtq at 6 psi ... a turbo of a smaller size is gonna put down somewhat less hp than that. like I said earlier, drivetofast's car with the sf kit and upgraded turbo, exhaust put out 155 whp at 5 psi. I don't know what these stock d17 t25 turbo guys are running at 6 psi, but I imagine it's less than 165 whp
Old Mar 12, 2005
  #63
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
wtf, why can't you figure it out?
the guy said not k20a2, k20a ... referring to the 13.5 1/4 mile ... which implies that the earlier person was making an unfair comparison with a k20a and a 13 psi turbo setup. obviously a turbo d17 at 13 psi is gonna pull on a k20a3 i/h/e
Old Mar 12, 2005
  #64
TheSmuggler's Avatar
lmfao... well I'll point out thatt he thread title is k20a3 vs d17 turbo and we ALL know what the answer to that is lmao
Old Mar 12, 2005
  #65
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
again, one opinion vs another.
I would choose the k20a3, rather than a 6 psi turbo setup
Old Mar 12, 2005
  #66
Cocky's Avatar
Cocky guys kick ass!
Originally Posted by civicrider01
I am going to be doing something to my 01 civic ex soon. Should I put a stock k20a3 in the vic, or should I turbocharge the D17 at 6 psi? I might end up doing the header and intake to the k20a3, but if I do the swap I wont be able to afford anything else. Which is faster, a 01 civic ex D17 turbocharged, or a 01 civic ex K20a3 (stock) swap?
swap to an a2, then boost.
Old Mar 12, 2005
  #67
So if it's your opinion who cares, it's an opinion thread then so stop trying to tell people who right and whos wrong. Opinions are just that, there is no correct answer...
Old Mar 12, 2005
  #68
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
when there are incorrect facts behind opinions, that is when I intervened
Old Mar 12, 2005
  #69
Well, I guess we should just leave this thread alone, people will do what They want to do with THEIR rides... we all have differen't wants and needs =)
Old Mar 12, 2005
  #70
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hm, let's make a list of the threads of all the turbo problems people have been having over the past 1 day
http://www.7thgencivic.com/forums/sh...d.php?t=201882
http://www.7thgencivic.com/forums/sh...d.php?t=201834
http://www.7thgencivic.com/forums/sh...d.php?t=201897
Old Mar 12, 2005
  #71
Lmao you just don't get it do you? PEOPLE CAN DO WHATEVER THEY WANT jebus lmao
Old Mar 12, 2005
  #72
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
um, this is a forum for posting information. nowhere in any of my posts did I say that the guy is only allowed to get a swap, idiot. and this is exactly what I am doing ... posting information and giving facts.
Old Mar 12, 2005
  #73
kornsined's Avatar
exactly why i'm not keen on turbos.
Old Mar 12, 2005
  #74
idk, i took it as he was saying to get a k20a, not a a2.....but then again, i have no idea who he was talking to. I am confuzzled ...... lol
Old Mar 12, 2005
  #75
Havok2k1's Avatar
Wicked Pissah Admin
How about you keep the name calling to your recess at school and let people have opinions.
Old Mar 14, 2005
  #76
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hee hee.
Old Mar 14, 2005
  #77
kornsined's Avatar
i think the k20a3 is a great engine. same torque as the k20a2 and a lot of people say both engines feel the same except for when the k20a2 hits vtec. IMO if i ever swap it'll be a k20a3 unless i find a crazy deal on the type s engine.
Old Mar 14, 2005
  #78
dezod's Avatar
7thgen Power Maker
To each his own. IMO this thread is beating a dead horse. If you want more headaches, and potential for power wth about $4000-5000 to play with....swap
If you can't be bothered with ECU, axle, clutch etc swaps....turbo the D17. It will make you a decent contender, if you want to get sick and be unique, get internals and crank the power to 13+ PSI. Cost for all of this is going to be $4000-5000 as well.
Reliability, swap is going to be a little more, but a turbo D17 that is tuned properly and not beaten to death can easily be reliable too.
Regardless of what the motor, a FWD car with 200-300 WHP is going to have severe traction issues.
Old Mar 14, 2005
  #79
kornsined's Avatar
beating a dead horse is right.
Old Mar 14, 2005
  #80
Old Mar 14, 2005
  #81
Nick's Avatar
Formerly 2blu
thats sick
Old Mar 14, 2005
  #82
kornsined's Avatar
Old Apr 7, 2005
  #83
ImportRacer2123's Avatar
K20 Member
Originally Posted by n20hcvc
Turbo 7thgen would beat a stock k20, even if the k20 had i/h/e.
Bullshit I raced a k20a2 swapped 7th gen when i was running a T25 10psi custom turbo kit. he walked all over me.
I also raced an ep3 with Injen Intake and pulled away.
Old Jul 14, 2005
  #84
Sup3rMariO's Avatar
Sup3rMariO is an unknown quantity at this point
Originally Posted by HondaLuver
but u see... you can turbo a k20a? and it will smoke a d17turbo like nothing...
SO TRUE!
Old Jul 14, 2005
  #85
allmotor's Avatar
nor cal 7thgens
obviously the swap would be better in the long run if u turbo, nitrous, n/a for easier #'s then having to extract so much out of a 1.7 etc . But the big question is how much hp u looking for? People have gotten over 300 hp on turboed d16y8 etc and some even 400. With the ems and more turbo parts/internals the d17 will soon do the same. So sometimes a turboed built d17a1 or 2 wouldnt be a bad decision either. Btw stop saying turboed cars wont last as long as n/a cars. Getting on ur car all the time is bad no matter what u done or have to it, and u think revving to 9 is good all the time. With a good tune, matienence, and goin easy on it, it should last a long time. People on honda-tech boost insane amount of hp on STOCK sleeves and blocks and some still havent blown anything. Lemme say also that i HAVE seen people turbo old d15 and d16 mtrs wit over 100,000 miles so far and no problems
Old Jul 15, 2005
  #86
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
1234
Old Jul 15, 2005
  #87
LayinLo's Avatar
LayinLo is an unknown quantity at this point
5678
Old Jul 15, 2005
  #88
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I don't even know why I looked in this thread. I knew it would be a bunch of bullshit, but here's my 2 cents anyway. If you've got $500 to $1000 buy nitrous. If you've got $2500 to $3500 go turbo D17. If you have enough for a swap and some serious mods (I would at least spray), then do that. No one way is better than the other until you line up side-by-side.
Old Jul 16, 2005
  #89
rum151's Avatar
rum151 is an unknown quantity at this point
my 2 cents aw well. ..
there sum <a href='http://consumeralertsystem.com/cas/zx-hclick.php?hid=181' target='_blank'>cat</a> on HSTuners.com and hes running a 2003 EM2 , stock D17a2 with a custom turbo kit i believe SF, and hes running 13's. , he and his crew are taking the engine apart and sleevn the block and adding internals.. lookn to try and do low 12's ... .. i didnt believe it but there was a vid on it with the turbo on stock D17a2. its prolly up there still i dont know, tho it was a while ago.
Old Jul 16, 2005
  #90
turboengnr's Avatar
DONT PANIC
a turbocharged D17A2 will go 13's on 9-10 psi of boost on a small T3. I have the timeslips to prove it.
Now i am going to prove that the D17A2 can go low 11's on a "slightly larger" turbo
**** by slightly larger, i mean freakin huge ****
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
