Timing Off???
Old Mar 5, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
Unhappy Timing Off???
well some of you guys know i'm boosted for about 6months now, but i thought i'd ask...
now boosting I know I need to get a piggyback ECU to compensate with fuel and timing... which I don't have, I only have VAFC2... my first question is
(NORMAL DRIVING) when i'm on first gear i nomally rev up to 5k rpm before I change gear... but my car hinders like it's choking out of air??? is my timing way off? this only happens on 1st gear NORMAL DRIVING, it doesn't happen when I floor it up to redline... VTEC set at 4500 <<<is this the reason why it kinda buggs down?
second question, if my timing is off, I already set up an appointment to get my ride dynoed, will my VAFC2 be able to change the timing? or I need a piggy back for this?
and yes, i read the basic boost guidlines... and I will read it again... like now! thanks for the input guys!
Old Mar 6, 2005
civic01vtec's Avatar
I wouldn't change the vtec settings at all. Leave them at the stock setting.
Normal driving isn't shifting from 1-2 at 5k.....i usually shift around 3 - 3.5k
You will not be able to change timing with the vafc....only the e-manage. Also, the vafc increases timing as is goes from vac to boost.
Old Mar 6, 2005
Balut Eating Champ
sorry double post
Old Mar 6, 2005
Balut Eating Champ
ow wow i didn't even know vafc increases timing... is that good? or bad? anyway, yeah i'll try to keep it below 4k RPM... thanks... i was just worried if i'm throwing a piston off or not...
Old Mar 6, 2005
the vafc does not increase any kind of timing, only a/f and vtec. If you have the vtec set that high, you are gonna have a flat spot between 2500rpms and 4500 (where yours is set). That's already been proven on a dyno. Leave the vtec stock and I bet your problem is solved, especially with turbo.
Old Mar 6, 2005
HyaBoosta's Avatar
yeah, most turbo cars when boosting like to retard the timing, but when I tried that on the dyno the car fell on it's face and lost 25whp after retarding the timng 3 deg.
Old Mar 6, 2005
Balut Eating Champ
OW ****!!! for real??? damn... aight so i got my VTEC set at 4500RPM for our car's last time i check was VTEC is set at 3700 stock right? C-M-I-I-W...
Old Mar 6, 2005
Leave it at [****] for stock engagement.
Old Mar 6, 2005
if that is what you think
Old Mar 6, 2005
of course when you retard timing you will lose power
Old Mar 6, 2005
Balut Eating Champ
actually i concur on what he said... coz i have my car buggs down on me in between those range, i just thought the ecu will compensate for it... and it comes and goes... or maybe i've been driving it for a while and i was just used to it...
Old Mar 6, 2005
Originally Posted by pnoyster2k1cvic
actually i concur on what he said... coz i have my car buggs down on me in between those range, i just thought the ecu will compensate for it... and i comes and goes... or maybe i was just used to it...
i meant about the timing
Old Mar 6, 2005
care to teach me how a/f corrections affect timing? And what kind of timing?
Old Mar 6, 2005
http://www.honda-tech.com/zerothread?id=841443
Old Mar 6, 2005
Balut Eating Champ
nice info, if this is in my native tongue... like "tang ina! wala akong naintindihan na putang inang numero! mamatay na sana ang nag imbento nito"
damn it... so even in low boost i'm friggin skrood!
Old Mar 6, 2005
did you try putting the vtec point back to stock?
Old Mar 6, 2005
Balut Eating Champ
^^^well there's no such option and or way to put it to [****] so i set it to 3700 and 3500 i think that's the stock setting right? it was on 4500 and 4300...
Old Mar 6, 2005
If you have the vafcII I promise you it does. That's the only way to get it stock. We're not sure on the engagement point, and it may actually vary depending on throttle position. Just play around with it and press different directions until the numbers become stars.
Old Mar 7, 2005
HyaBoosta's Avatar
yeah Im pretty sure in the directions there is a way to reset the vafc
Old Mar 7, 2005
djmota's Avatar
The **** is stock setting you can get there by turning it backwards. As gearbox said this will solve your problem and improve lower end power.
Old Mar 7, 2005
Balut Eating Champ
i turned it all the way down and it only goes to 2000 and that's it
Old Mar 7, 2005
No there is a way to make the numbers disappear and turn into stars. Try pressing the little control thing to the right or something. There is a way, you just have to try different things in that menu.
Old Mar 8, 2005
Balut Eating Champ
i'll try again...
Old Mar 8, 2005
If you still can't figure it out, I'll play with it and tell you exactly what to push tomorrow
Old Mar 8, 2005
Balut Eating Champ
i got it!!! yeeeyyy!!! thanks gear ... it is now back to stock **** by just pressing and holding the button to the right for about 3secs.. seems fine... but i don't feel the kick as much when it was at 4500 RPM
Old Mar 9, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
so if I'm running 6-7psi, will I need to retard the timing at all, or just leave it alone and make sure it doesn't run lean? I don't want to blow a hg or snap a rod......= bad, very bad....lol
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
