Super Charger vs. Turbo
Old Mar 3, 2005
i8dabomb's Avatar
I love to suck t3h c0ck & am supr ghey
i8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nice
can someone here please give me a few links on superchargers and turbos... like which system adds the most horsepower. props + rep to whoever helps out.
Old Mar 4, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
On the same system and boost level a turbo will make more power. The supercharger uses crank power to run. The turbo uses "wasted" energy to compress the air. This makes it more efficient.
http://auto.howstuffworks.com/turbo.htm
http://auto.howstuffworks.com/question122.htm
Old Mar 4, 2005
2K1Civic17"Gabe's Avatar
I cant believe this wasnt locked right away.
Since everybody says "NO SUPERCHARGER FOR OUR CARS". But, yeah, there are none, unless you have a K series motor.
turbo will get you a good HP gain
Old Mar 4, 2005
i8dabomb's Avatar
i know there arent any superchargers for our engines... i was just saying
Old Mar 4, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
Not necessarily, it also depends on the volume of air being pushed. If a supercharger and a turbo run at the same psi but the supercharger has 150 more cfm of air, it'll create more power.
Old Mar 4, 2005
phydo's Avatar
phydo is an unknown quantity at this point
Well, if there is 10psi of pressure in the intake area, with each, then you have the *same* quantity of air, given it's at the same temperature, which means you should get the same power, right? Correct me if I'm wrong, just tryin to use logic, I'm not claimin to know everything
Old Mar 4, 2005
Wrong. If a supercharger and turbocharger run at the same psi, they are moving the same amount of air.
At a set pressure level, on the same engine, a turbo and supercharger will flow the SAME amount of air. You don't "push" air through a motor. All a turbo does is increase the pressure in the manifold, which increases flow. The engine will move the same amount of air for a given pressure regardless of how it got there.
Old Mar 4, 2005
You won't make the same power, because the supercharger is using power derived directly from the crankshaft to compress air.
Old Mar 4, 2005
PunkingCivic's Avatar
I need TP for my bunghole
http://www.turbocalculator.com/turbo...ercharger.html
Old Mar 4, 2005
A turbo and a supercharger are basically compressors, so you can pressurized 2 differents volumes of air at the same psi. Think about it.
Old Mar 4, 2005
No. They compress air relative to the engine.
Old Mar 4, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Now if you want to get technical, there are several diffent types of superchargers.
Positive displacment Roots Type:
Pros: Instant boost
Cons: Air inside a roots type is constantly compressed, expanded, and compressed over and over when the engine isn't running WOT. This heat soaks the intake manifold (if ceramic) and intake temp's can reach up to 100+ degrees. This particular supercharger is difficult to intercool.
Centrifical type: This type is basically followed the concept of a turbocharger. What would be the exhaust side, is ran off of the belt. The belt runs gears inside this supercharger, spooling up the compressor.
Pros: More compact, easier to intercool
Cons: Low boost at low RPMs. The faster the engine runs, the more boost this type creates. A centrifical supercharger pretty much feels like a larger engine.
If any of this is incorrect, plz correct me, thanx.
Old Mar 4, 2005
Boosting Daily
TheSmuggler00 [8:22 PM]: supercharge > turb for realiability and driveability
TheSmuggler00 [8:23 PM]: Turbo > supercharger for performance
TheSmuggler00 [8:23 PM]: well
TheSmuggler00 [8:23 PM]: to an extent
EternalBlueVic [8:23 PM]: all motor > all for realiability and driveability
EternalBlueVic [8:23 PM]: own3d
EternalBlueVic [8:23 PM]: haha
TheSmuggler00 [8:23 PM]: lmao
TheSmuggler00 [8:23 PM]: hahahaahah
TheSmuggler00 [8:23 PM]: not necessarily biotch
TheSmuggler00 [8:23 PM]: lkmao
Old Mar 4, 2005
TheSmuggler's Avatar
^^There is an intelligent conversation in the making
Old Mar 4, 2005
iamboo's Avatar
Retired - SoCal FI Mod
gawdamnit.... this has been asked numerous times... refer back to turbo faq or search the F/I forums... thanks
HondaGuy7
Feb 22, 2016 01:00 PM
Cam Diaz
Sep 29, 2015 07:17 PM
General DIY
Sep 25, 2015 08:02 PM
h4ldol
Sep 17, 2015 01:25 PM
MamaBear2015
Sep 7, 2015 06:00 PM
