AEM EMS Now Available
Old Feb 16, 2005
  #31
kezay's Avatar
kezay is an unknown quantity at this point
Mirage one quick question ..... The 30-1070 EMS will not allow the factory AC or temp guage to work. However when the 30-1030 EMS is released will there be a way of probably upgrading (whether it be hardware or software) the 30-1070 EMS so that these things could work? The reason I am asking is because if I purchase the
30-1070 EMS and then 1 year down the road the 30-1030 EMS is released then I would want that issue resolved. BTW thanks for having some faith in the D17. F*ck Hondata.
Old Feb 16, 2005
  #32
wonderz's Avatar
wonderz is on a distinguished road
Originally Posted by Gotti
I like it. And I want it.
you have an boosted auto, right?
Originally Posted by Mirage
14. It DOES NOT work on A/T cars.
Old Feb 16, 2005
  #33
Mirage's Avatar
Mirage is an unknown quantity at this point
When the 1030 is released we will supercede the 1070 and we will make a hardware upgrade available for the existing 1070's that want the additional features, but it won't be free. However, we won't use it as a method to make money off people who bought the 1070 either. The 1030 will have a higher selling price than the 1070 due to the harness so I suspect the difference in price will be the cost of the upgrade. But I am not comitting to it just yet.
Also, you can use your factory A/C with the 1070, you just need to wire in a switch to the EMS. We think that's kind of ghetto so we are still doing the 1030. The EMS will also be able to see and display the engine temp, but it can't talk to the coolant gauge in the cluster so it doesnt show there. You can always make your check engine light come on if the engine gets too hot. You can do that without any wiring at all.
Old Feb 16, 2005
  #34
kezay's Avatar
Great. ...
Bump for a great product....
Old Feb 16, 2005
  #35
kezay's Avatar
The only question now is where do I get it to buy it at the lowest price ???
Old Feb 16, 2005
  #36
pnoyster2k1cvic's Avatar
Balut Eating Champ
i'll probably wait untill somebody sells theirs for cheap
Old Feb 16, 2005
  #37
Mirage's Avatar
You have to be careful about that. If you get it in a group buy or a no-support internet shop they who do you turn to when you have questions? You may end up screwing yourself in the long run for a $50 savings. I would recommend getting it from a shop that will sell it as a dyno tuned kit. That way, you know how much $$$ you are going to be in for.
Old Feb 16, 2005
  #38
z00mX's Avatar
z00mX is an unknown quantity at this point
hmmm... wondering if it will still work for the 06 si... cause my bro planning on getting the new si
Old Feb 17, 2005
  #39
opto_isolator's Avatar
Unless honda redesigned their bus system it would probably require minor tweaking on AEM's behalf. A good example - the 05 RSX has a different ECU than the 01-04's. Hondata's Kpro doesn't work with the 05 RSX.
In regards to the EMS - I may invest in one of these versus dumping my car, if I can ever afford it. This would definitely sort out all my little annoyances with turboing a car that doesn't like to be turboed....
One thing's for sure - if the pricepoint is right, it WILL cut into hondata's buisness - which will be interesting. Hondata chose to limit themselves by ONLY working on the K20 - quite possibly the EMS will effect their buisness decisions enough to cause them to re-think their buisness model - and support other engines besides the K20.
It sure will be interesting to see what happens!
Old Feb 17, 2005
  #40
Just noticed something interesting on AEM's web site about the 1030 however, which is a little disappointing.
According to their engineer, JP:
30-1030
Advantage: Will run 01-up Honda Multiplex System which drives the Coolant Gauge and A/C Input Switch.
Disadvantage: Requires 2 ECUs to be run in the vehicle
You read that right - you still need to run your STOCK ECU in addition to the EMS.....Its an add-on, but not a full replacement.
That's sort of disappointing.
Old Feb 17, 2005
  #41
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I wish I hadn't just bought all my Emanage stuff.
Old Feb 17, 2005
  #42
Changu-San's Avatar
Mr. Clean
any lab rats yet?
Old Feb 17, 2005
  #43
Mirage's Avatar
Originally Posted by opto_isolator
Just noticed something interesting on AEM's web site about the 1030 however, which is a little disappointing.........
The 1030 will plug into your factory harness just like the 1070. But it will have a small (10 wires or so) harness that will go to your factory ECU. The factory ECU will be fed enough data to correctly dispaly the coolant temp on the gauge and activate the A/C. it wont "do" anything with the engine at all.
IMHO, I would just get the 1070. The basemap supplied has the check engine light acting as an "idiot light" when the car gets too hot and a simple 2 wire switch can be hooked to the ECU and activate the A/C request line.
BTW, the 1070's started shipping today. They should trickle down to shops within a week or so.
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
