turbo guru's HELP!!!!!!!!!!!!!!!!!!!!
Old Feb 11, 2005
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
please help me out im hooking up my turbo to my crx and i cant remember what vacume lines go to where.
without a boost controller do you use the top or bottom line off the wastegate that goes to the turbo. (tial wastgate)
and top or bottom line off the bov???
HELP!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 11, 2005
^^^^^^^^ help
Old Feb 11, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Old Feb 11, 2005
AceAltima's Avatar
AceAltima is an unknown quantity at this point
To simplify those above instructions (i understand, but not many seem to be able to decipher them)
The side nipple should be referenced off a source, preferably the compressor itsself...if that is not attainable, a source from the charge pipe before the TB will suffice....and lastly if you can't use either of the above use actualy intake source...
I'd suggest teh compressor housing...but to each his own
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
