91 octane
Old Feb 9, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Angry 91 octane
how can I run 91 octane and not kill the motor. I have tried retarding the cam and nothing helps. I never had any problems running 100 in germany but in cali 91 is all you got. I can't even get to 2 psi without having problems. any help?
Old Feb 9, 2005
civicskater's Avatar
Chicks dig my scent
if all you were doin was running 100 octane then your car is used to that. And by goin to 91 octane its basically in shock due to the lower octane and running shitier. And you'll need to mess with ignition timing not cam timing
Old Feb 10, 2005
exturbo6's Avatar
they dont sell race gas for there is not sunoco out there to get high octane gas???
Old Feb 10, 2005
civic01vtec's Avatar
exactly
Old Feb 10, 2005
drjvic04's Avatar
drjvic04 is on a distinguished road
If you live close to an airport some of those gas stations carry higher octane so be on the look out. Do you use those octane boosters?
Old Feb 10, 2005
turboengnr's Avatar
DONT PANIC
if you retard the cam timing, it retards the ignition timing in most cars. (havent played with a cam gear in this one).
Set your cam timing to zero. And if you have any ignition controls, set them to about where stock was. You should be able to run 7-8 psi on 91 octane with no problems with the stock timing curve.
Old Feb 11, 2005
2K1Civic17"Gabe's Avatar
yeah, and I saw somewhere on here that different countries have different ways of measuring their octane. So say your 100 or 101, could be like 91 or 93 here. The US has different ways of measuring everything from like every other country. So it makes sense.
Old Feb 11, 2005
allmotor's Avatar
nor cal 7thgens
lol crew chief thats why stockton sucks. I talked to some n/a guys and even they get mad at cali's shitty gas
Old Feb 11, 2005
CrewChief's Avatar
ok I had an ELD problem I fixed I hope that fixes my problem. I don't think it is the gas after all. has to be another system malfuntion. will know soon. I'll keep you posted.
Old Feb 14, 2005
Thats what i said. Hope it all works out
shaejb15
Jul 27, 2015 03:48 PM
fvckbg
Jul 7, 2015 07:08 PM
crazyjetskier
May 17, 2002 07:02 PM
FLiPpIeS
Apr 15, 2002 12:14 AM
BassmanJP
Apr 10, 2002 10:11 PM
