how much boost can i run if i wideband dyno tune it?
ok...im just wondering how much boost i can safely and reliabily run on a stock d17...i'll probably run medium - rich to play it safe
my fuel management will be the e-manage, injectors and fuel pressure regulator....
so whats a safe psi to run once i get wideband dyno tuned...
10-12 on stock internals?? how RELIABLE is that even with a awesome tuner
the guy tuning my car is unbelievable...probably the best tuner around...http://www.lr-racing.com/main.htm
thats his website... as you see he tuned a supra for 800 whp.. and he has many 11 sec dsm's laying around the shop.... one of his workers has a h22 boosted runnin low 12's in a 1st gen integ...
DONT PANIC
im not trying to debate on his tuning abilities.
before i started having trouble with my injectors, i was running 11 psi daily. My car has been turbod for 2 years. So i would say its pretty reliable. I only broke it 1 time, which was a head gasket and i was on 4 psi. I had trouble with the fuel system and it lead to it popping a head gasket. i have had worse luck on low boost than on high boost.
After i fixed the head gasket i was running around on 10-11 psi daily until my injectors started failing on me.
Originally Posted by turboengnr
some people ran 10-12 psi daily. Its all pretty much on the skill of the person dyno tuning your car.
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
