A little advice needed
Hey im looking at getting a turbo kit in the next couple of weeks
... i was looking at this kit http://store.yahoo.com/cheapturbo/starterkit1.html ... I figure id go with the same size turbo as the dezoid stage 2.... I also figure im gonna need a manifold, fuel system, e-manage, bov, injectors (RSXs ???), e-manage, and piping... Any one suggest have any suggestions on which company parts to use and if i left anything out... Also when does the stock civic tranny/clutch start to go bye bye...
... i was looking at this kit http://store.yahoo.com/cheapturbo/starterkit1.html ... I figure id go with the same size turbo as the dezoid stage 2.... I also figure im gonna need a manifold, fuel system, e-manage, bov, injectors (RSXs ???), e-manage, and piping... Any one suggest have any suggestions on which company parts to use and if i left anything out... Also when does the stock civic tranny/clutch start to go bye bye... Samoan<^>(-_-)<^>Power
t3/04e+tial 38mm wg+ tial bov+intercooler=1500. i guess its a good deal. as far as everything else you need, it looks like you've listed them all. get rsx-s injectors, get dezods manifold, you only need 1 emanage system so get that, custom charge piping as well as a down pipe, all the nuts,bolts,washer,vacuum and oil lines/fittings etc and you should be straight. might as well by dezods kit...
Take a look at this and it will give you a start.....
Turbo FAQ ownz
http://www.7thgencivic.com/forums/sh...d.php?t=174045
Turbo FAQ ownz
crowtoo
May 11, 2015 06:50 PM
