Getting This Turbo Kit Got a question
Old Jan 18, 2005
AndrewD's Avatar
AndrewD is an unknown quantity at this point
Here is what the Seller has listed on E-bay.
I reacently bought this kit brand new. I was going to install in on my 2000 civic ex. I was going to install it during my winter break but ran short on money because I have to pay for school. Here are the specs. These descriptions are exactly like the one from the person i bought the kit from. Sale is final, the product is sold as is.
Fits any "D"-series motor. including D15, D16 ( Z SERIES OK ) This manifold was custom-made to be used with a 35mm or 38mm external wastegate and this manifold and down-pipe allows you to retain A/C and power steering.
This manifold and downpipe is for Garrett T3 and T3/T4 Turbos. The manifold and down-pipe are both made out of SUS304 Hi-Grade Stainless to help disperse heat. This manifold is drag-race quality, and similarly design manifolds can be found on professional drag cars. Manifold has flange for an external wastegate. And since this manifold is tubular steel, it flows better than cheap cast iron and is less prone to cracking.
Down-pipe allows you to retain your A/C and power steering. There is a flange for the end of the down-pipe will bolt-on to your catalytic converter so you do no have to cut and weld your exhaust to make this down-pipe fit. Down-pipe also has a bung for the O2 sensor.
TURBO INFO FOR D16 CIVIC TURBO -
Brand New in The Box - TURBO 3" INLET DIAMETER 2" OUTLET WET FLOATING BALL BEARINGS 1/8 NPT OIL INLET T3 / T4 FOOTPRINT OK !! SPECS: .57 COMPRESSOR WHEEL TRIM GARRETT STAGE III .60 A/R COMPRESSOR .63 A/R TURBINE THIS TURBO CAN EASILY DO 25 psi 530 whp MANIFOLD AND DOWNPIPE AND TURBO PICS LIST BRAND NEW TURBO BRAND NEW MANIFOLD DOWNPIPE WITH O2 BUNG 90 DEGREE ELBOW GASKET SET BOLT SET CAT FLANGE TURBO EXHAUST FLANGE
BUYER TO PAY ACTUAL SHIPPING
PIc of it to.
Here is my question, if I purchease this kit I don't seem to see that it comes with the Piping that connects from the Throttle body to the intercooler. " Isn't that the piping where the blowoff valve is" should it come with that piping, Do I need to buy it some where else? and if so, where else? is this a bad kit? I plan on purcheasing an intercooler, will that come with the piping I need. How does this work?
Old Jan 18, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
We have a D17. That kit won't fit your car.
Old Jan 18, 2005
AndrewD's Avatar
I have a D15
Old Jan 18, 2005
AndrewD's Avatar
Going on a 94 Civic Del Sol..
Old Jan 18, 2005
Mirage's Avatar
Mirage is an unknown quantity at this point
Hate to be the one who breaks this bit of news to you, but you are on the wrong forum.
Old Jan 18, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Wet floating ball bearing?
Old Jan 18, 2005
TheSmuggler's Avatar
^^Actually hes not
Old Jan 18, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
i'd do custom pipings, but that's just me.
Old Jan 18, 2005
AndrewD's Avatar
So I can go to my local shop, to get the piping and they can bend it for me?
Old Jan 18, 2005
gotti's Avatar
^ yep
Old Jan 18, 2005
civic01vtec's Avatar
this is a public forum, he can post if he wants to
Old Jan 18, 2005
that is ssautochrome.........they make shitty manifolds
Old Jan 20, 2005
Mirage's Avatar
Well, of course. But if he is looking for specific information about getting a turbo for his D15, then he could do much better than 7thgencivic.com.
Old Jan 20, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
I never thought it would hurt to ask, there ARE some people on this forum that know MORE then D17 engines... and if it bothers you that much that hes posting something about a d15 engine... well.. go walk it off...
Old Jan 20, 2005
dezod's Avatar
7thgen Power Maker
It seems like an intercooler-less system. This makes charge temps into the TB higher, which hinders HP. Is the Del Sol motor built at all for boost (pistons, rods...)? What about fuel management? Engine management?
Old Jan 20, 2005
04CivicLX's Avatar
04CivicLX is an unknown quantity at this point
What size Intercooler do you think will fit the best on the Del Sol?
Will you think this one will work?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Jan 21, 2005
allmotor's Avatar
nor cal 7thgens
my neighbor is about to go boost on his del sol. Should be pretty quick. If you want more info try honda-tech.com and looked at the fi forums or del-sol forums
Old Jan 21, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
the way i read it...it hardly sounds like a kit...sounds like just the turbo, manifold and downpipe...
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
NoobyKid
Jul 13, 2015 07:53 AM
chrisjackson321
Jul 12, 2015 03:00 PM
