questoion on return oil line & turbo pics
hey I am looking at where the oil return fitting hangs and it's almost horizontal with the oil pan point that I want tot tap. how shoud I run the line?
I can curve the line more but how much is safe?
My sexy IC
Garrett T3/T4 w/SFP manifold
Another shot
SFP down pipe with electronic cut out and high flow cat
Another shot
My sexy IC
Another shot
Another shot
I'm curious too. My install will probably be next month and this is the part I'm most worried about. If you can't get it to work, maybe a different fitting would help. I'd hate to lose the Aeroquip but maybe it's too long.
What size is the drain line #10 ? what about using a 45 degree out of the bottom of the turbo to angle it more to top of the oil pan? I think it would be much better to use a angled fitting then to try to flex/bend and kink the line . Looking good BTW
Originally Posted by HyaBoosta
thanks. yeah im going to try the 45 fitting. I have to pick it up. dam there goes another 8 bucks
yeah the drain on the turbo is -10an and so is the fitting going in the oil pan
I need TP for my bunghole
Originally Posted by mxcivic
wondering if theres a electric oil pump that can help to drain the ool from turbo tu carter....
but here is an electric oil pump:
http://www.emp-corp.com/html/product...c_oil_pump.htm
yeah, a 45 will work.........make sure u get it as high as possible.
btw..........everything looks pimp........just wondering why you yanked your motor ?
Wild Cranker
427
Jan 28, 2016 06:49 PM
RIPSAW
Nov 6, 2015 04:36 AM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
