turbo or nitrous
Old Jan 13, 2005
  #31
allmotor's Avatar
nor cal 7thgens
you mean modacar? I didnt know they offered the kit that cheap.
Old Jan 13, 2005
  #32
04civicdx's Avatar
04civicdx is an unknown quantity at this point
Talking
that is what it said and thanks for the info i am going n2o as son as i get some cash
Old Jan 13, 2005
  #33
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Originally Posted by EternalBlue_Vic
If you decide to go with nitrous....go with a wet shot, AND start with the lowest possible shot to gain experience, etc. Also, never spray in 5th, and always spray above 3000rpms.......and pray you don't miss shift with a WOT sprayer actuator....
Then again, I ran 80 shots for the first time with my Edelbrock kit. Im currently running 80 with no problems. Im still going to get the AEM UEGO to make sure everything is running good.
I spray on any gear as long is it is in wide open throttle.
Old Jan 13, 2005
  #34
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
^^ good man
Old Jan 13, 2005
  #35
Originally Posted by 04civicdx
hay thiscrakerntam what is the diff from a safc and a safc2 and modcar has a nx kit for 565 is that cheap sorry about all the ? but i whant to know what i am getting my self in to and how much i need to save and thank you for all your help thiscrakerntam
the difference is the safc2 is more advanced.
Old Jan 14, 2005
  #36
im stock now! T.T
all nitrous kits are basically the same. edelbrock is complete. it also comes w ith pressure gauge.
Old Jan 14, 2005
  #37
^^how do u figure they are all about the same? All of them are designed to work differently in various ways...
Old Jan 14, 2005
  #38
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
Having sold the UEGO may I reccomend that you DO NOT go with their product? The UEGO takes slower sampling rates than many of the other companies and he connectors break during install . Happened to me twice on customers' cars.
If you look at sampling rates and accurate range, the best currently on the market are the PLX Devices units. the read fully and accurately 10.0:1 -20.0:1.
Just food for thought... not to mention the PLX depending on options can be cheaper than the UEGO.
Old Jan 14, 2005
  #39
djmota's Avatar
check out honda-tech's sponsor market place afor some even cheaper prices for kits. 535 for zex or nx last time I checked.
Old Jan 17, 2005
  #40
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
hondata says if you are gonna spray anything over a 40 shot on a k you have to upgrade injectors and fuel pump.
Old Jan 17, 2005
  #41
im stock now! T.T
mines is the single channel wideband. not just the uego. must be wideband if you want accuracy.
Old Jan 17, 2005
  #42
allmotor's Avatar
nor cal 7thgens
b18c1boy i have seen people shot over 40 on a k without any fuel system, but they would benefit especially with a 75 if they had a fuel return setup with injectors, fpr, fuel pump instead of the returnless setup stock
Old Jan 17, 2005
  #43
Pb4uGo's Avatar
err thats what i'm talking about... the UEGO wideband...
Old Jan 18, 2005
  #44
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
man.....whats a VEGO???? I got a 50 shot NX on a LX and I think Its doing great....and I'm smoking hatchs with h22 and rsx-s.........but I don't know much about safc and a safc2....will my car run better if I put something like that? fuel pump? should I be able to get a better aftermarket fuel pump?...where?
Old Jan 18, 2005
  #45
oh and I got my NX kit from JEGS.com and it was like $585.00 some shops were pricing me about $800 for the same one!
Old Jan 18, 2005
  #46
^^with a safc, version 2 or not, you can tune on the dyno with it and yes it will run better. The only real purposeful way to add in a larger fuel pump is to make it a return system, but you dont need to do that because the NX kits are designed to work on stock fuel systems. Good start on the kill list.
Old Jan 18, 2005
  #47
I got my NX kit from them too. I would recommend them to anyone, their service was top notch, plus you get free shipping
Old Jan 18, 2005
  #48
im stock now! T.T
its UE GO not vego. you dont really need a fuel pump. the UEGO will help monitor your air/fuel ratio. so you will know if ur about to detonate.its basically an accurate air/fuel ratio gauge that tells u the exact ratio unlike cheapos where they tell you o nly if you run lean or rich. you can check ur plugs too but id rather have a nice gauge.it means universal gas oxygen sensor. i doubt h22s and type-s will lose.
Old Jan 18, 2005
  #49
ok....Man...realize how much hp and Torque RSX-S and H22s have at the wheels.....a 50 shot with a warm bottle makes about 100 torque and at least 60 hp!!! I tell man....I got both of them...same night!!!!infront of everybody!
Old Jan 18, 2005
  #50
I think its possible for him to win against both.
Old Jan 18, 2005
  #51
im stock now! T.T
a 50shot should give you about 160 to the wheels without i/h/e
trust me man, unless you got alot of bolt-ons because they help alot, especially when you spray.
Old Jan 19, 2005
  #52
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
I believe that he's gotten over on type-S's and h22s .... I personally have smoked 2 type s's in the same day and that was running a Zex 75 shot with no warmer or pressure guage .... And as for the "hope you dont misshift" crap, I was spraying on a run and hit a patch of wet asphalt and bounced of the rev limiter and absolutely nothing happened ( other than scaring the crap outta me ) .... I mean, I wouldn't do it just for fun but sometimes mistakes happen ... doesn't mean your car is gonna blow up ... I've been spraying for almost 2 years now and other than oil changes and a new battery, my Civic has never even seen the shop for any repair ....
Old Jan 19, 2005
  #53
^^people always pay so much attention to the hp numbers....what they dont think about is, when it comes to nitrous, its not all about the hp. Its about the torque. Nitrous gives you A LOT of torque, and its the torque that moves you down the track for the most part, not the hp.
Old Jan 19, 2005
  #54
like I said.....I don't know about others systems but NX on a dyno show that with a 50 shot doubles the torque in our cars! on the wheels! cuz I have a friend he dyno tested with and with out and he made like 105 wtq and then with 950 psi he made 203 wtq or something like that! with a 50shot!
Old Jan 19, 2005
  #55
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
That's exactly why I've decided to go NX instead of ZEX.
Old Jan 19, 2005
  #56
So i don't understand why u doubt about me smoking type s's and h22s.....have u tried?....get the 50 shot and try it!!!!! the let us know....
Old Jan 19, 2005
  #57
I think I blew my head gasket which is probably my own fault, but I still say NX is the best.
Old Jan 19, 2005
  #58
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
how much does install of a nitrous kit usually cost?
Old Jan 19, 2005
  #59
about $200, but if you cant install nitrous yourself you shouldnt being using it. Thats just my two cents.
Old Jan 19, 2005
  #60
Redline04's Avatar
Civic redline said it not me. I believe you, because there's a type-S here that runs the same times as me and I'm NA.If you can drive they shouldn't be a problem with a 50 shot.
