Internal W/G vs External W/G
Old Jan 7, 2005
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
Question Internal W/G vs External W/G
what is the diffrence bettween an internal wastegate and an external one??
Old Jan 7, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Internal
when the boost pressure is equal or greater to the spring in the actuator diapragham, the actuator pushes an arm that opens a gate inside the ehaust manifold that allows exhaust to bypass the exhaust turbine when peak pressure it reached.
Pros: Cheaper
Cons: the wastegate on internal ones tend to be small, and not ideal for heavily boosted setups
External
Mounts directly onto the turbo manifold, or elsewhere. When the boost pressure is equal to or greater to the spring setting on the wastegate, it pushes the gate open and exhaust bypasses the turbo and is either recirculated the the exhaust system or vented to the atmosphere (open dump)
Pros: Easier to tune, more reliable
Cons: More expensive.
Old Jan 7, 2005
abmerop18's Avatar
Jam out with your clam out.
i got a tial 38 mm external wastegate and it pwns all. not really that expensive. you can find a used one for like $150 shipped on www.honda-tech.com
mine:
Old Jan 8, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
I am getting a 34mm interal wastegate with my upgraded EVO III Turbo
HondaGuy7
Feb 22, 2016 01:00 PM
C-Hamm
Sep 28, 2015 10:31 PM
