Top 10 Boost Problems?
Old Jan 7, 2005
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
Question Top 10 Boost Problems?
whats up guys/gals.
well i'll be boosted in hopfully 22 weeks and i was curious what the 10 ten boosted civic problems are. and are they easy to fix.
Old Jan 7, 2005
civic01vtec's Avatar
Headgaskets
blown pistons/rings
clutch
tires
Old Jan 7, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Not knowing how to install/tune correctly.
Old Jan 7, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
10. Fitment
9. Shitty install guide.
8. The guy with the key to the shop never shows up when hes supposed to.
7. Working with a heavy *** manifold in a tight space
6. Return line leaks
5. WIRING!!
4. Relocating the battery for room
3. TUNING!!
2. MORE TUNING!!
1. Bald azz tires after a few weeks
this was just my top 10
Old Jan 7, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Originally Posted by civic01vtec
Headgaskets
blown pistons/rings
clutch
tires
Just check on clamps and pipes, to make sure they are tight and connected.
BTW. you have 22weeks to learn. (That is like what, almost a half of year)
Old Jan 8, 2005
HyaBoosta's Avatar
Emanage def. ranks up there. a pain to work that tight space and to get it up and running right
Old Jan 8, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
BLOWN TURBO!!!!!!!!!!!!.... lol
Old Jan 8, 2005
Biggest problem is...................... $$$$$$$$$$$$$$$
Old Jan 8, 2005
down_'s Avatar
well the $$ wont be a problem....and im small ehough to sit cumfortably in the passanger side of the car w/ the seat all the way back (were your feet go) emanager shouldnt be that much of a problem i had to re-wire my vafc so im somewhat of a pro when it comes to my ecu. i am alitte worried about the tunning though...how much did it run you guys to tune?
Old Jan 8, 2005
BLOWN TURBO was my number one problem.. lol... we still need to meet up yo.. lol
Old Jan 8, 2005
would you care to make a bet
Old Jan 8, 2005
oh yea.. if you need tuning done and what not i'll help you on that since you only live in the same area as me...
Old Jan 8, 2005
money wasnt a problem with me.. just the fact that a blew the damn thing.. and instead of wasting money on fixing it i though i would just do a motor swap instead
Old Jan 8, 2005
MadWheel's Avatar
Premium Boosted Member
Head gasket
clutch
spark plugs
map sensor
rings+pistons
tires
misfiring
i blew a coil once!
The other stuff shouldn't really be a problem if it's all done correctly. IE, leaks, blown turbo (sometimes defective), wiring isn't a problem, its just hard...
I dunno, everything that could go wrong on my old set up went wrong. So I listed some major probs I could remember.
Old Jan 9, 2005
Boosting Daily
know of anyones crank bearings to go bad?
Old Jan 11, 2005
down_'s Avatar
yea..40,000 says i wont have a problem lol . I dont plan on running that much boost maybe 5-6psi but thats about it. i dont want to do damage to the internals seeing as im not doing any internal work. i'll intall head studs so that should help some. but im not going crazy with it....when i get it i'll hit you up mike i'd like to do the install myself ( to learn) but im hesitent. how much does tunning generaly run..TOTAL.
edit: yes i know i could just buy a new car or whatever but for now im content with my civic. i just wana give it a little ummffff...and the rest of the $$ is kinda for school
Old Jan 11, 2005
do what i did... boost 15lbs and watch your turbo go bye bye.. lol.. surprising my engine didnt go... but dang honda engines are built strong
Old Jan 14, 2005
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
I just changed my HG....only problem I've had since I've had the car....head was fine surprising considering the fact my HG has been blown since shortly after I put the turbo on (since June '04)....my HG wasnt BLOWN BLOWN but it did have pinholes in it and my compression was ALWAYS fine but my overflow tank ALWAYS stayed full and my car would run like shitt after being on it a few times consecutively. Other than that...NO PROBLEMS
Old Jul 22, 2005
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
i want a turbo
Old Jul 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by mkymonkey
i want a turbo
buy/make one then
Old Jul 22, 2005
mkymonkey's Avatar
yeah but all my money is going to school. two years from now once i graduate
Old Jul 22, 2005
Boosting Daily
i want a turbo
i miss my turbo
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Supramk3
May 11, 2015 07:55 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
Flatlander
Nov 16, 2001 05:38 PM
