head gasket
head gasket
i dont know if this is the right place for this topic but whats a good thick head gasket to use. and how much do you think it would cost to get installed. would using a thicker HG be a safe way to turn up the boost to say 10psi?
It would certainly help your engine handle 10psi of boost better, but as you know already, the only true safe way is to build your internals
A nice headgasket will help decrease the risk of detonation in your engine, but will not decrease the pressure that the turbo creates ontop of your pistons...
i so guess i need around 3 or 4 grand to build this thing the right way. i would like to run more then 10psi. i wanna get the all out of my turbo. thats my goal by june or july.
Exactly...thats the downfall of high boost...you need to do it correctly, and thats about all there is that can be said...
I'd love doing tihngs on a budget, but when it comes to boost, doing things cheaply will only bite you in the *** and only cost you more in the end...no one ever said going fast was cheap lol
But def a built bottom end is the way to go...you'll able to boost ALOT more and SAFER...which is what everybody wants
as for 2 headgaskts I wouldn't even ever let 2 headgaskets get near my car at the same time (unless it's a v8 lol)
2 headgaskets is a sure way to have problems...lol...you can't just 'stack' the gaskets and hope for compression to not be lost...heck everyone would jut go out and buy 4 or 6 gaskets if it was that easy ;]
Originally Posted by Civic Type S
I am getting one nippon leakless head gasket to be installed this week, I will let everyone know how It goes, also getting an Exedy stage 2 clutch if I can get a good price
PM Jeff at Streetlevelperformance.........he has great prices for them
hit him up on aim at jdobson412
yeah i need a new clutch myself. i saw the exedy stage 2 for 220 i believe. and as for the motor i guess ill just save up and build this thing...i think its worth it. i wanna go faster.
i am gonna get the exedy organic.........it is better for daily driving and can hold 69% tq over stock.
Balut Eating Champ
ow ****! I just found the right topic! this is my next project! I've heared sad stories about headgasket blowin up, and they have to clean all the fukin oil spills under the hood...
any 7thgen done this before? and also can ya'll post a DIY, I can take anything out of the engine, but it would be hell to put them back on
haha!
so ok 2 Nippon Leakless! so pleaaaaaaaaaseeeeee help me with DIY!!!!
haha!
no dude, they are saying do not stack headgaskets!!!! that is a very bad idea. they would just leak or even blow out. there is a reason HG's are as thin as they are. if the HG was thicker, if would leak sooner because it wouldn't be as strong. the thinner the gasket, the stronger it is when you squish it between two metal surfaces. but of course too thin is bad and won't give a good seal. think about it, engineers have designed gaskets for years and they make them so they work the best way possible. so if a thicker/stacked gasket was better, it would be done that way from the factory. Oh, thanks for the help with my topic on my turbo problem, I fixed it this morning and she runs nice and smooth. but always remember, doubling gaskets is a no no, and if someone does it they should be shot....lol
Gasket Works USA (626) 358-1616
Custom copper headgaskets in whatever thickness you need. Will not blow out and you can lower compression with them if you really want to.
That's how my F22B1 was sealed together before my current rebuild. NO problems what so ever with their product.
Balut Eating Champ
and don't punch the sucka untill you get it tuned! you'll regret it!
and ow! sorry yeah only one gasket!!!!
and don't stack em...
who ever said stacking them up is good should be shot
they said nippon leakless is good too... what about some titanium block pins to hold the head down? you guys heared of those? and where can I get em? I think there's more to it than just the gasket but what holds it in place... Last edited by pnoyster2k1cvic; Jan 6, 2005 at 05:54 PM.
My OEM HG held reliably to 14# before it was replaced with the copper gasket, the OEM did not leak nor did it blow out, it was simply a safety measure, the trick is in the headbolts. Honda headbolts are torque to yield which means that they stretch when you install them and apply a clamping load on the head.
You MUST not reuse OEM headbolts as they will never seal correctly again, going to ARP hardware will button it down as tight as you will ever need on a Honda engine running pump gas.
Balut Eating Champ
If you are talking about dowel pins, I seriously doubt anyone here is making near enough power to have the head shift enough for that.
I have an extra genuine oem head gasket lying in the bedroom, but its made by ishnu which is what honda was using before they switched to the nippon leakless gasket. This is what I heard anyway. Would the Ishnu gasket that I have be ok to replace the original with if I use ARP head studs, or should I get a different gasket?
robbie374
Jul 7, 2015 02:56 AM
jdawgzcivic
Jun 30, 2015 06:35 PM
HondaHomer
May 14, 2015 12:24 PM
