additional injector controller
Old Dec 20, 2004
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
hey what's up guys. I've searched and found only two old posts on this subject. What do you guys really think about these (Greedy Rebic and HKS AIC) and would you recommed it. I need too know because I am going to do my turbo in a few weeks and I have no fuel system yet. Thanks again guys.
Old Dec 20, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
I have the haltech f5 additional injector controller on my car, have for more than two years with no fuel related problems.
The Rebic and HKS are decent units, but not as accurate or as tunable as the Haltech F5. I'm using one additional 460 injector just before the throttle body, and it's enough for 10psi. Above that, the stock pump will not flow enough, so you're pretty much limited there.
The MaxRev kit came with a system like this... the ERL MF2 or some name like that. It used two additional injectors (overkill) and a halfway decent control box that was tunable, good for the money but not as accurate as the Haltech.
Old Dec 20, 2004
I just basically want to know if it's an affective and safe way to put more fuel in your engine when under boost. I heard Haltech shut down is that correct. I was thinking of getting the greddy rebic or the Hks AIC.
Old Dec 20, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I have the ERL MF2 and i have had not had a problem with it since ive had the kit.
Old Dec 20, 2004
First to spool
Haltech has not shut down, their major USA importer (Haltech is Australian) closed down. You can still get Haltech products, but you have to get them from a different source, is all.
Additional injector systems are safe, as long as you have a large enough injector and remember the limits of the stock fuel system.
Old Dec 20, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
how does the TSI injector controller unit compared to the ones mentioned?
Old Dec 20, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Tsi unit is great. Have no experience with the others But I like the TSI one. Easy to use and controllable through rpm and psi range. Also is a turbo timer.
jzhartman
22
Jul 23, 2015 10:42 PM
califcamper
Jul 21, 2015 10:34 PM
krazykoncepts
Jul 14, 2015 01:55 PM
