Is this turbo too small?
Old Dec 18, 2004
abmerop18's Avatar
Jam out with your clam out.
i am beginning to lean towards a t3 .48 trim .48 a/r instead of the t3 super 60 .48 a/r. i dont really want a turbo that is gonna spool late like 3400+ like the super 60, and am beginning to think the 48 trim would be better. i am looking to boost 8 psi daily and maybe bump it up to 10 or 11 for the track and shoot for a goal of 200-215 whp. do you think this is possible with the 48 trim? what turbo would you guys suggest?
also, does anyone know exactly at what RPM the t3 super 60 spools up on the 7thgen?
Old Dec 18, 2004
hustlelikem0fo's Avatar
just stick with nawz
Old Dec 18, 2004
abmerop18's Avatar
^ stupid ricers
Old Dec 18, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I certainly hope that you're not saying that people who use nitrous are ricers because I really dont wanna get started and I dont think you want me to either.
Old Dec 18, 2004
abmerop18's Avatar
im joking with hustle. he knows that. lets keep this on topic please
Old Dec 18, 2004
ok cool...
Old Dec 18, 2004
yea, dude, dont be dissin nawz.
when i see a turbo blow floor boards of out a car then i'll have some respect for it.... but until then nawz ownz
Old Dec 19, 2004
tfnaaf's Avatar
BLDNPSI Mod
Old Dec 19, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
that turbo is basically the same one that i got with my sf kit....the standard .48 trim is a good turbo for what you want to do...it spools quickly and pulls hard....you wont be disappointed
Old Dec 20, 2004
BIG's Avatar
BIG
I went the same route abmerop18.......should eb at full boost around 1500-1700 RPM..
Old Dec 28, 2004
abmerop18's Avatar
anyone know at what rpm the t3 super 60 .48 a/r would spool at?
Old Dec 28, 2004
MadWheel's Avatar
Premium Boosted Member
bout 3200 to start spooling...
what kind of wastegate you plan on using? what type of boost controller?
my blitz sbc-spec s would get my t3/t04b to spool up pretty quick. so get a big exhaust, and good boost management and you'll be able to easily spool it at around 2500 or so
Old Dec 28, 2004
abmerop18's Avatar
i have a greddy profec b spec II EBC and a 38 mm Tial wastegate
Old Dec 28, 2004
98oRange's Avatar
98oRange is an unknown quantity at this point
if you want a quick spool use a t25. NO idea what the spool is. It sound fine but you might want to get bigger injectors. Unless you already have em
Old Dec 28, 2004
03civda's Avatar
03civda is an unknown quantity at this point
no turbo is too small
Old Dec 28, 2004
I hope you're not being serious
Old Dec 28, 2004
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
dunno but I am going t3/t04e
Old Dec 29, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
You make a good pont, but 2500 is super soon...you must have your B/C setup very gradual huh?? I know on my 2.4 I don't have full 12 psi until about 3200 and thats on a t3t04b, .60 comp/.63 turb
Why waste your time...by the time you're spooled you'll be shifting...
I dont think I can stress enough how much fun a big a/r BBt-28 would be on your car...on an sr20, at 16 pounds you're easily at 300 whp...and let me tell you how much fun MIDRANGE torque and power is...
Maybe it's just me, but i'd rather have strong powr from 2500 to 55/6000 rather than lag and a tad more pwer from 3500/ to 6000
Old Dec 29, 2004
nickm748's Avatar
The greddy T88 spools up fast! Get that one
Hers the link
2nd one down
http://members.shaw.ca/kfgroup/Turbo%20Comp.htm
Old Dec 29, 2004
dezod's Avatar
7thgen Power Maker
I see power @ 3000 RPMS, full boost (8 PSI) on the AUTO @ circa 4200-4500 RPMS.
People need to speak more from facts & experience and not what they heard.....
Old Dec 29, 2004
MadWheel's Avatar
The turbo you're talking about had a .63 exhaust turbine. The most common setup I see on 7thgens uses a .48 exhaust turbine. That will spool up a lot faster than your car did on the .63. Plus, not sure of your nissan, but civics have a decently high compression, thus aiding spoolup.
Old Dec 29, 2004
dezod's Avatar
7thgen Power Maker
All depends upon how much power you want, and where you want it distributed.
The larger T3/T04E will make far more power at 8 psi than the BB T25. The flow rate is far greater on the T3/T04E/.
The T25 power band levels out at 4500 RPMS. It becomes very inefficient after that and just creates immense heat. BUT....this turbo might be nice for a daily driver just making the drive to and from work fun from stop sign to red lights.
The T3 Super 60 RIPS power from 3000 RPMS to and past redline. On my dyno sheets, @ the 6500 RPM mark, my power curve was still climbing without sign of any fall off. This turbo distributes power from 3500-6500 easily at 8 PSI, and is well within it compressor range. 8 PSI= PR of 1.5. Trace this line across, and you'll see your SMACK in the middle of the turbo's most efficient through a good 2/3 of the power band.
Edit: Not to mention, if you build the engine, it will get EVEN more efficient up to and including 20 PSI.
Old Dec 29, 2004
AceAltima's Avatar
The super 60 is a nice lil turbo...I'm surprized more boosters in general don't use it...
You also hit the nail on the head about the daily driver aspect, I assumed that was what he was going for wit his kit
As for compression: Yea we're down aroudn 9.2/9.3 to 1, so not to much (good for boost tho :])...not to sound like a NewB, but what is the compresion of a standard d17 (i truthfully don't know)
Old Dec 29, 2004
dezod's Avatar
7thgen Power Maker
9.9 for EX VTEC
Old Dec 29, 2004
abmerop18's Avatar
lx has lower compression pistons, right?
Old Dec 29, 2004
doubledeuce2k2's Avatar
yes it does, 9.5:1
Old Dec 29, 2004
abmerop18's Avatar
w00t for the lx. and im getting hte t3 super 60 y0 and the 3" exhaust with apexi n1 muffler
Old Dec 29, 2004
AceAltima's Avatar
sounds like a good plan /\ /\ /\
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
bhollie
Sep 22, 2015 11:08 PM
pilebuck13
Sep 21, 2015 10:45 PM
