Anybody with a K24a hybrid?
Old Dec 16, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
Who's got one done? I'm in the process of gathering all my parts to do this swap. Any input that anyone can provide would be great.
Old Dec 16, 2004
HondaLuver's Avatar
Its a celebration bitches!
ummm, almost... what do u want to know/?
Old Dec 16, 2004
SIinthesky's Avatar
From what I know this swap is pretty straight forward. I was wondering if anyone experienced any problem during the process of the swap that I need to know about? I seems like an easy hybrid. At least easier than building a B20 Vtec.
Old Dec 16, 2004
ren808's Avatar
ren808 is on a distinguished road
is there mounts for the k24 swap. i know its hella cheap to buy the swap but is it better than the k20? what kinda parts are there for it and are they more of less expensive the k20.....inquiring minds want to know.
Old Dec 16, 2004
SIinthesky's Avatar
The mount to put a k24 in a civic ex are sold by hasport for 5-600 bucks. You will also need a bunch of other stuff too. If you got a SI it should be the same mounts as long as your using the SI manual tranny. I'm putting the K20a2 head on the K24 for true Vtec action. Its easiest to do this if you have both engines complete.
Old Dec 16, 2004
JDM-EM2's Avatar
JDM-EM2 is an unknown quantity at this point
Im doing the same K24 swap. I am using the TSX 2.4 Block with the TSX Head. I spoken to the owner at P1 Auto who does hybrid K24 swaps.....he told me that if I have hold of a TSX head instead of the RSX Type S ....to use the TSX. Im going to use the DC5 Type R tranny...got one for $2,000. I know expensive huh ? My TSX head is brand new from Acura as long as my RSX Type S manifold. I got my block for $600. hehehe I work at my local Acura....i get the parts for cost. helps out alot I am planning to get the turbo kit from Cybernation once it's devlop....i have been talking to one of the owner's Chris, he told me they been lookinh to buy a 6spd TSX both have no luck. My luck I have one.....so I might be selling them the future project TSX. It's black.....and they want blue or silver. So who knows...but the K24 is a big Turbo block to go for not all motor.
Old Dec 16, 2004
SIinthesky's Avatar
Are you using the RSX-S intake mani and TB. Thats the only way to get rid of the drive-by-wire setup that the TSX has. Also the RSX-S ECU. I want to run a turbo as well and thats why i'm going for the CRV block. Its compression is only 9.6:1 compared to the TSX's, which is i bit higher. Also the TSX engine is expensive and hard to get.
Old Dec 16, 2004
JDM-EM2's Avatar
Yes I have the RSX Type S TB and intake manifold. Also I will be using the RSX Type S PRB ECU. Im still saving up a lil more money and plan on sending ECU to Hondata for the upgrade , programable ECU for $1,000. I got my TSX Head, RSX TB and manifold and other small parts from work brand new $1,500. So it wasnt so expensive for me. I also got the K24 TSX and K20 TYPES block both real cheap.... $600....hehehehe all i had to do was replace oil pan on K24 and change a rod in the K20. So i have back up block too...hehehe
Old Dec 17, 2004
ren808's Avatar
DAMN.......thats expensive. isnt cheaper to get the k20ar. or the type s with lsd. i didnt even know that hasport came out with the mounts yet, if they did why arnt they on the website
Old Dec 17, 2004
SIinthesky's Avatar
Here's the link for the mounts http://hasport.com/catalog/product_i...products_id=40
JDM-EM2-can you let me know where you sourced these parts from at these prices?
Old Dec 17, 2004
doubledeuce2k2's Avatar
he says he works at a dealership.
Old Dec 17, 2004
SIinthesky's Avatar
Did you get the blocks from the dealer you work at? Or off of Ebay or something? I found some really good deals at http://www.car-part.com/ Its a national junkyard locator
Old Dec 18, 2004
JDM-EM2's Avatar
I got them from work. My K24 block has 2,200 miles on it .I will be getting rid of 2 other K20 blocks. Soon i will have three blocks. I only need one. I will most likely post them on ebay. RSX Type S Block and a Integra Type R Block.
heheheh im spending alot of money building my Frankenstein motor.
Old Jan 6, 2005
DFCivic's Avatar
DFCivic is an unknown quantity at this point
So this owner of P1 does hybrid k24's. There has been a lot of speculation that the accord and element k24 blocks will hit the valves on the type-s head and wont work without new pistons. And that the crv k24 is safe without high revving. I have been trying to figure out this dilemma for awhile because im itching to do it and i found a cheap accord motor i want to pick up.
Can you give me the contact info for this shop, i'd like to talk to him. And also ask him whats the true story about this since he has real experience.
Thanks.
Old Jan 6, 2005
HondaLuver's Avatar
yea.... u think its cheap? just wait till its turboed and tunned
Old Jan 6, 2005
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
k24 with type s head will never clear hood. deck height is too taal.
Old Jan 6, 2005
DFCivic's Avatar
I will probably not go turbo for awhile even if i decide to do it. The accord motor i speak of is only 7 bills. And thats dirt cheap. If i can use that, my frank setup will be complete for not much more.
Old Jan 6, 2005
DFCivic's Avatar
Actaully, the enjo mounts claim they have solved this problem.
http://www.enjoracing.com/engine_mounts_swap.html
Old Jan 6, 2005
CiViCLiZeD714's Avatar
Has anyone done a k24 swap with these mounts??? I'd like to know if they actually fixed the height problem.
Old Jan 7, 2005
b18c1boy's Avatar
howd they fix it? by dragging the oil pan on the ground.
Old Jan 9, 2005
HondaLuver's Avatar
^^^ what if they did? and your point is? whats with the negativity
mgrantaz
General
May 2, 2022 05:40 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
charmon4815
General
Sep 22, 2015 08:00 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
