my turbo story (auto)
Old Dec 12, 2004
kkk's Avatar
kkk
kkk has a little shameless behaviour in the past
heylo all
my turbo setup was totally a home made project and the car was an auto 2001 civic .
i used the turbo setup for 20 days. nothing much was done, it was all basic
with a T25 turbo , intercooler, BOV and AFCII with some boost gauges and internal wastegate setup till 6-7 PSI.
i was very much sick and tired by the comments of ppl saying tht the setup wasnt all tht good. so i dicided to take the turbo out.
now during tht 20 days, this is was happened to my car.
1) when the car was cold , it would throw out white/grey smoke.
after taking out the turbo , the smoke dissapeared automatically. any idea wat would had been the problem?
i had alook at the auto thread and would like to know wat is gear slipping??
right now , i am building up my turbo setup again these are a few things which i am gonna get for my new setup
1) T25 turbo ( same old one)
2) front mount intercooler
3) BOV ( old)
4) Forged pistons
5) Rsx injectors
6) Return line (i am actualy gonna takeout a return line from the stock fuel rail i hope this works :S )
7) Fmu
8) AFCII (old)
9) boost controller
10) new fuel pump
wat more should i get? again , i am planning on only 8-9 psi not more
plus , i am planning to add in a wet shot Nitro kit.
thanxs
p.s= i had no problems with my auto tranny but after taking out the setup , i had to change my inner axel which connects to the gear (thts wat i was told by my mechanic)
Old Dec 12, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
talk to gotti, his setup would be a good one to follow as well...
however nto being rude, if you're only going to boost 8-9 pounds after a built motor, why not just swap smethign worthwhile???
Old Dec 12, 2004
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by kkk
heylo all
3) BOV ( old)
4) Forged pistons
5) Rsx injectors
7) Fmu
8) AFCII (old)
9) boost controller
10) new fuel pump
thanxs
return fuel system shouldnt be a problem at all. if your gunna do pistons id sugest rods while your at it. When you say FMU, do you mean as in a vortech style ? no idea why you would need to change the axle .....shrug. Sounds like you have the basics
Old Dec 12, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
broken axle = bad @ street races esp when popo is around
Old Dec 13, 2004
kkk's Avatar
kkk
engine swap would b the last thing i would do.... to much work and plus it would avoid my insurance fmu (fuel pressure regulator)
one thing i wanted to know was if i get e-manage, will i b still needed a boost controller?
Old Dec 13, 2004
HyaBoosta's Avatar
sounds like when you had the turbo on the first time that you havd an oil leak somewhere. is that turbo brand new when you bought it?
Old Dec 13, 2004
kkk's Avatar
kkk
no i broguht it used.
well i did have some boost leak which i could not detect . but after opening up the header to replace with my stock one , i found tht the packing was all broken into pieces with some attached with the header and the rest dropped somewhere. mayb tht was the reason i wasnt getting full boost? well i would like to know wat material packing should i give this time?
Old Dec 13, 2004
HyaBoosta's Avatar
yeah have the turbo checked out it sounds like one of the seals inside is bad.
Old Dec 13, 2004
kkk's Avatar
kkk
questions
1) wat does gear slipping feel like?
2) how do i check the turbo for any broken seals?
3) wat packing should i use for the header ( engine block to the 4 header pipes, originally steel packing was used shall i use them for the turbo too? cause somone said it would not work cause of more temp.)
4) if i use e-manage do i need boost controller?
Old Dec 13, 2004
civic01vtec's Avatar
some ppl prefer f/i over n/a and knowing that he can run 8-9 psi safely is quite a good idea.
Boosting 8-9 provides more performance over a k20 swap *(waits for k20 swapped members to flame)*
Old Dec 15, 2004
mxcivic's Avatar
mxcivic is an unknown quantity at this point
i just installed my turbo and theres a lil smokje white/grey too, what can be ?
Old Dec 15, 2004
tfnaaf's Avatar
BLDNPSI Mod
seals bad in the turbo ?
Old Dec 15, 2004
where is the smoke coming from ?
Old Dec 15, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
the first time that you installed the turbo you did not have a fuel system. I say that the fuel pump and the injectors are a must and a great move the second time around. If you would have kept running without them even at 6 psi your rings would have not lasted very long
Old Dec 15, 2004
mxcivic's Avatar
exhaust i guess i just test it today and in a stop i sae the smoke to came from behind i didnt pop the hood if theres something wrong there ill check it whit time...
Old Dec 15, 2004
mxcivic's Avatar
ill check that ...
Old Dec 16, 2004
allmotor's Avatar
nor cal 7thgens
while ur motors out might as well sleeve it
Old Dec 18, 2004
kkk's Avatar
kkk
is engine swap a better option for me or boosting it?
Old Dec 18, 2004
key word............ me
it all depends on what you want out of ur ride.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Theshwartz35
Jul 18, 2015 10:49 PM
Yazan93
Jul 14, 2015 08:56 PM
Jul 12, 2015 11:54 AM
