Different turbo stages
Old Dec 10, 2004
yche086's Avatar
yche086 is an unknown quantity at this point
Ok I've had a search here, and I couldn't seem to find anything related to this dumb question I'm about to ask... what is this stage 1 turbo, stage 2 turbo etc business? Yes, I know it's a dumb question, but hey everyone's gotta start somewhere
Old Dec 10, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
you might have been reading the different stage cybernation kits for K20 swapped vics. Or it might have been a generaliztion of stage 1: just boost, and stage 2: boosted with internals. Etc
Old Dec 10, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
If you hear "stage" it generally refers to the turbine wheel.
Old Dec 10, 2004
Titleist71's Avatar
You don't know either do you....Turbo Stages can mean a range of things. You can call a Stage 1 Turbo one thing and it may mean something different to someone else. Various "stages" use various components. Turbo XS has Stages 1-4 on the UTEC for WRX's. A ECM (UTEC) has turbo stages also. EternalBlue is right, it also has to do with boost, boost stages. Turbo stages is very vague. I guees what I'm saying is that their is no real textbook defitnition that I know of. There are various meanings. Keep searching go to clubrsx.com and some subaru boards and you may find more info. GL.
Old Dec 10, 2004
Boosting Daily
I don't get to hear that very often! Rep for that!!
Old Dec 10, 2004
Titleist71's Avatar
Okayyyyy...Thanks Dooood!! Props to the Eternal Blue owners, I got ur back. We represent.I'm out.
Old Dec 10, 2004
turboengnr's Avatar
DONT PANIC
There are different stage exhaust turbines for turbos. The most common turbine in a t3 is a stage 1. It is in just about all T3's regardless of the .ar rating on the exhaust. Basically, the higher the stage, the larger diameter the exhaust turbine is. Then you have the trims. The trim is sometimes designated by a number, but most commonly designated by a letter (example, T3 turbo with a Stage 3 "P" trim turbine).
Now i have also heard the phrase "i have a 67 trim wheel". Basically that means that they have a 67mm inducer on their compressor wheel. And they can have a specific AOA (angle of attack) on their blades. The more aggressive the AOA is on the compressor, the quicker the spoolup time, but the lower maximum airflow. So you have to balance the AOA to achieve the spoolup and airflow that you want.
We have all heard the phrase "Stage II Turbo". Basically that is some Grand Turismo ricer crap. It is like the "Nawz" of the turbo world. Just like there is no "nawz", there really is no set "Stage II Turbo". Some manufacturers specify their turbos as "Stage I, II, etc", but it is really only to organize their parts in order from cheap to expensive.
Old Dec 10, 2004
Titleist71's Avatar
^^^ well put!
Old Dec 12, 2004
Look through the turbonetics catalog for instance, the only "stage" referred to is the turbine wheels.
Old Dec 12, 2004
Titleist71's Avatar
thats just in that catalog. There are many, many other meanings and references to "stages".
Old Dec 12, 2004
civic01vtec's Avatar
werd......... stages refer to certain upgrades
stage 2 could have a bigger intercooler than the stage 1 and/or have a bigger turbo........etc..
Old Dec 12, 2004
TheSmuggler's Avatar
Yup, so basically you should tell us where you see stage then we can look at it and tell you what it means. I'd say 9/10 times though stage refers to you getting more parts the higher the stage (hey whered stage -1 go lol i can't afford 1)
Old Dec 12, 2004
Agreed, but he asked about a turbo, not a kit.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
beanhead
Sep 24, 2015 12:04 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
