what oil to use with a turbo??
Old Dec 9, 2004
bakablo's Avatar
bakablo is an unknown quantity at this point
im getting all kind of advce....
theyre telling menot to go with 5w20 syn or close..
they are telling me 10w40,20w40 should I.. im a bit confused!!
Old Dec 9, 2004
dezod's Avatar
7thgen Power Maker
5w 30 or 10x 30 synthetic will be fine
Old Dec 9, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Beofre a track event I use 10w50 oil
normal driving i use 10w30
Old Dec 9, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
10w 30 synthetic
Old Dec 10, 2004
HyaBoosta's Avatar
5w 30 sythetic. same your using now. you just have to change it more often
Old Dec 10, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
I was using 5w 30 before I got my turbo on. After installation, I had some oil problems so I switched to 15w 40. However, later on I found out that it was actually the turbo that was faulty not the oil. But still I am using 15w 40. As a reference, I'll quote you these few lines from 'Maximum Boost' by Corky Bell:
"In general it is best to avoid wide-range, multiviscosity oils, as the materials added that create the multiviscosity capability are the same materials that cause the coking. Thus 20W-50 is clearly better turbo oil than 10W-50."
Hope this helps!
Old Dec 10, 2004
dezod's Avatar
7thgen Power Maker
Hope this helps!
What page is that on?
Old Dec 10, 2004
HyaBoosta's Avatar
I never saw that in there
Old Dec 10, 2004
dezod's Avatar
7thgen Power Maker
That's what I am saying.....Please prove me wrong.
Old Dec 10, 2004
HyaBoosta's Avatar
high viscocity might be better for the turbo but your engine is still reccomended 5w 20. a higher weight and viscosity can't be good for the oil pump
Old Dec 11, 2004
civic01vtec's Avatar
i am using mobil 1 5w-30
Old Dec 11, 2004
Ahtasham's Avatar
Sure
Chapter 4. TURBOCHARGER LUBRICATION
Sub heading: Selecting a Lubricating Oil
Page number: 40
Lines: 24-27
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
brags
46
Jan 7, 2016 09:39 PM
jessica19699
Jul 29, 2015 05:51 AM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
