question about spark plugs (not a noob thing)
Old Dec 1, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
2k1HXVTEC should not be trusted2k1HXVTEC should not be trusted2k1HXVTEC should not be trusted
hey, i have a question about spark plugs. i have a 50 shot nitrous kit installed in my hx cvt. i live in colorado springs 3 months out of the year (~7000ft) and in roswell, nm the rest (~3500ft). just to be safe when i got the kit i ordered a set of zex hyperformance plugs which i believe are two steps colder than stock. they ran great installed even in springs but after driving awhile and checking them i believe i have carbon deposits (they have a dark coating). are these too cold for the altitude? what heat range should i go with? would stock heat plugs be fine considering the altitude?
Old Dec 1, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
If you're running nitrous, then leave the plugs in. You may consider 1 step hotter, but still 1 step colder than stock if it is badly coated.
Old Dec 1, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
sounds good, thanks for the info.
Old Dec 2, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
What do you have them gapped at?
Old Dec 2, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
the zex plugs are pre-gapped
Old Dec 2, 2004
I just remembered that they have 3 electrodes which might make it hard to even check the gap on them. I dont usually trust the pre-gap. I'm used to always checking them. I use NGK's and the shorter I have the gap, the richer it burns, but it also runs rougher at idle. I think I have my gap set a little shorter than stock .040. I cant remember. I need to change them out right very soon anyway. Maybe you should try using a different plug. I've heard a couple of bad remarks regarding the zex plugs.
Old Dec 2, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
well, they are working fine, i doubt its the gap as carbon deposits are usually due too cold of a plug. i noticed after using the bottle a couple times that these deposits are being cleaned away which probably means they are just fine.
Old Dec 2, 2004
Whatever you say dude...mine are 2 step colder and they've never put any dark coating on my plugs. Just make sure you keep them changed often. Plugs dont last with nitrous regardless if they look ok or not.
Old Dec 2, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
you also live in tampa florida. last time i checked tampa was at sea level, but hey, what do i know? besides, i have heard very positive remarks from some members about the zex plugs and some negative ones about the ngk's so i guess its just personal experience.
Old Dec 2, 2004
which ngk's?
Old Dec 2, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
the only ones that go two steps colder, the ngk racing plugs which i also have a set of.
Old Dec 2, 2004
which ngks?
Old Dec 4, 2004
johnnyslil01ex's Avatar
Soon to be Mr. GST
johnnyslil01ex should not be trustedjohnnyslil01ex should not be trustedjohnnyslil01ex should not be trusted
ngk#7's (1 step colder) #7 are honda boost plugs, older hondas ran #5 oem while we run #6 #7 is what most shops have so thats what Im assuming that you have. Never run multi grounding electrode plugs of nitrous BIG NO NO...boost yes, nitrous no. ngks are rgeat, but with a 50 you could run stock plugs. I actually ran denso IK20's on my 50 then went the ngk 7's for my 75.
Old Dec 4, 2004
BKR7E to be exact, but you're wasting your time. He apparently already has everything figured out. He first post a thread about what a DIY bottle heater. Most people are telling him not to do it, but he wants to do it anyway. Somethin tells me that hes gonna use the ZEX plugs anyway.
Old Dec 4, 2004
I hope hes not runnin dry kit too.
Old Dec 4, 2004
Soon to be Mr. GST
oh man, if he is I could only wish hed race out in dallas, that would be beautiful....lmao....you'd hear rowl, rowl....poof....and a piston would blow through the hood...lol
Old Dec 4, 2004
whatever he does, I home he doesnt wire it up wrong like that one guy did who blew up his whole car.
Old Dec 7, 2004
2k1HXVTEC's Avatar
THE CHOSEN ONE
wtf, of course i dont have a fuc*ing dry kit. Anyway, i installed the NGK's and i checked them after a few runs with no spray. Same deal. gapped them to stock specs and they also have carbon fouling everywhere except for the very tip which is more the normal color. Why dont you idiots quit talking smack while your at it and be a little more productive.
Old Dec 7, 2004
Of course you're going to have carbon everywhere except on the tip. Thats how its supposed to look, moron. Why dont you quit postin and go buy a real bottle heater instead of trying to rig up some makeshift sunbeam back warmer.
Old Dec 7, 2004
Soon to be Mr. GST
well, I was being productive, but now im gonna talk mad smack cause ur an ***.....he he he...I will have half the site ***** out this thread until their's nothing left...dont **** me off...anyway, if your running engine management(vafc/safc/emanage) run stock fuel maps, or else you'llfoul out the plugs...if the ceramic has brown spots on it then your running too rich..
Being an ******* and helpful at the same time....he he he
Johnny G
Old Dec 7, 2004
Just look at the title of this thread. It says (not a noob thing) Thats false advertisement. If you go back and read his other thread he posted http://www.7thgencivic.com/forums/sh...d.php?t=185797
He clearly states that he just recently purchased and installed his nitrous kit. The reason why hes creating threads is because he is requesting input and feedback and because he doesnt like what he is hearing, he is now acting like a know-it-all *****. Whatever dude.
Old Dec 7, 2004
Soon to be Mr. GST
word...i didnt know this....its time to get people to ***** his threads he he he....Im evil...
Old Dec 7, 2004
HAHAHAHAHAHA
<~~~~~wh0re in progress
Old Dec 7, 2004
Soon to be Mr. GST
oh man drop it....***** time!!!!!!!!!!!!!
Old Dec 7, 2004
Soon to be Mr. GST
Whoring out this ****....YEEEEEEEEEEAAAAAAAAAAAAHHHHHHHHHHH!!!!!!!!!!
Old Dec 7, 2004
Soon to be Mr. GST
word!!!!! F-this Ish Up!!!!!!!!!
Old Dec 7, 2004
[b]YAY I HAVE A DIY BOTTLE HEATER YAY!9999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 9999999999999999999999999999999999999999999999
Old Dec 7, 2004
Soon to be Mr. GST
YAY!!!!!!!
Old Dec 7, 2004
Old Dec 7, 2004
Soon to be Mr. GST
lmao, we could out ***** a hooker on nickel night!!!!
