E-Manage Update re: 1106 CEL, Injector Correction Factor & Missing Link
Old Nov 20, 2004
dezod's Avatar
7thgen Power Maker
As many of you know, we are running the E-Manage on our turbo kit....With running the RSX Type S injectors, and the E-Manage to control them, one would want to utilize the injector correction factor for various reasons. So being the type of guy I am, I decided to do some experimenting.......
1) Used ML, E-Manage (no volt clamp), RSX S inj's, Inj corr factor:240CC --> 320
result: good fuel economy, no sputters, no chokes, CEL 1106
2) Used ML, E-Manage E-Manage (no volt clamp), RSX S inj's, no inj corr factor
result: poor fuel economy, too rich CEL , no 1106 CEL , choked and swam in fuel.....car was a slug
3) No ML, E-Manage E-Manage (with volt clamp), RSX S inj's, no inj corr factor
4) No ML, E-Manage E-Manage (with volt clamp), RSX S inj's, inj corr factor: 240CC--> 320CC
result:good fuel economy, no sputters, no chokes, CEL 1106
5) No ML, E-Manage E-Manage (with volt clamp), RSX S inj's, inj corr factor: 240CC--> 290CC
result:decent fuel economy, no sputters, no chokes, no 1106 CEL
What does all this mean?
This means the injector correction factor on the E-Manage causes the 1106 (map sensor error, not the ML). If the injector correction factor is set to more a variance than .80 (I think is the exact amount) in the injector correction factor part of the E-Manage, it throughs a CEL 1106 because it draws down the voltage too much on the map sensor, and creates a voltage variance that the ECU doesn't like at throws an 1106 CEL.
I thought this would be VERY helpful FYI to some of you being plagued by the same thing.
And to conclude my findings, I will put back on the Missing Link with the 240-290CC injector correction factor to complete it after I confirm .80 is the threshold on the ECU.
Old Nov 20, 2004
abmerop18's Avatar
Jam out with your clam out.
so does that mean you are not using the injectors to their full potential?
Old Nov 20, 2004
opto_isolator's Avatar
Some ECUs may just be more sensitive than others. I have mine set to 240 ->360 with no problems. There are a few other members who are using 440 injectors from RC with no probs - I really wish I knew why yours is causing problems.
Hopefully hondata will be able to do something with the D series ECU which will eliminate all of these headaches!
Old Nov 20, 2004
abmerop18's Avatar
could it have anything to do with the fact that your car is an auto tranny and your ECU is different because of that. just an idea
Old Nov 20, 2004
dezod's Avatar
7thgen Power Maker
Not sure, just stating my logged observations...........
Old Nov 20, 2004
civic01vtec's Avatar
excellent post
I am glad that you guys are playing with this and finding out the problems b4 i install mine
Old Nov 20, 2004
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by civic01vtec
excellent post
Old Nov 21, 2004
dezod's Avatar
7thgen Power Maker
excellent post
Hook us up w/ the some rep points then!
Old Nov 21, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Great feed back Dezod.
As always leading the way.
Thanks dude
Old Nov 21, 2004
abmerop18's Avatar
Old Nov 21, 2004
andyman97's Avatar
Turbo Guru
How big of an injector has the emanage shown it can support. By that, I mean tried and true results that show some consistancy. Oh, and opto, I'd really like to pick your brain a little about some fuel questions.
Old Nov 21, 2004
Titleist71's Avatar
It's very nice of you guys to share this also....it's very helpful to guys like me who don't have time or money to R&E all this....I'm a slam bam thank you ma'am, gimme fuel gimme fire gimme that boost of which I desire guy!
Old Nov 21, 2004
Ask away -
Let me rephrase my reply from eariler. As far as tuning / fuel go - I really don't have problems driving.
However, there are a few quirks with the setup I have. The first is that the car doesn't idle correctly 100% of the time. I am trying to fix that, but it may come with more tuning.
The other thing is that on cold starts I get a few random misfires every once in a while from idle to 2000 RPMs....
Other than those annoying little problems, I tuned my partial throttle area more this weekend - it works nicely now in partial throttle (it doesn't just dump more fuel than I need). It still needs work, but I can feel a difference.
Old Nov 21, 2004
dezod's Avatar
7thgen Power Maker
No.......
Old Nov 21, 2004
abmerop18's Avatar
No.......
no they are not working to their full potential or
no they are still working at 320cc
Old Nov 22, 2004
dezod's Avatar
7thgen Power Maker
Their full potential is 320CC
Old Nov 22, 2004
HyaBoosta's Avatar
does anyone know how many wires are on their main harness for the emenage. I have 11 (it's from the greddy rsx kit) But on the diy I have a black and red and an oragne left. nayone know? maybe they joined the injector and main harness in the same connector?
Old Nov 22, 2004
dezod's Avatar
7thgen Power Maker
DIS DIAGRAM PWNZ J00~
Quit hijacking too........
Old Nov 22, 2004
HyaBoosta's Avatar
sorry for the hijack just thought since everyone who had an emanage was on this thread that it could help. I still have 2 extra wires, but i'll give it a shot.
Back on topic
Old Nov 22, 2004
dezod's Avatar
7thgen Power Maker
Back on topic
It's ok.........I was just playin
Hope that helps
Old Nov 23, 2004
dezod's Avatar
7thgen Power Maker
up!!!!!
Old Nov 23, 2004
dezod's Avatar
7thgen Power Maker
Went back to ML...........Not too fond personally of the voltage clamp.
Used ML, E-Manage (no volt clamp), RSX S inj's, Inj corr factor:240CC --> 300
results after 2 days: good fuel economy, no sputters, no chokes, very smooth driveability, No CEL 1106 so far
Old Nov 24, 2004
dezod's Avatar
7thgen Power Maker
Still no CEL
Old Nov 25, 2004
import2nr's Avatar
awd pwnz j00
awesome post...
Old Nov 25, 2004
nindoo's Avatar
Why is my vagina bleeding?
This is a noob question.
But lets say you have the turbo kit, and you don't install bigger fuel injectors and you don't upgrade your ECU. Will you just have a car that runs really lean, with better fuel economy ? Or will it cause problems?
Old Nov 25, 2004
dezod's Avatar
7thgen Power Maker
YES! You are jepordizing your entire motor like that.
Old Nov 25, 2004
nindoo's Avatar
Will Combustion take place to early?
Old Nov 26, 2004
dezod's Avatar
7thgen Power Maker
The lean fuel conditions raise EGT's to alarming rates, which in turn burn and warp internal components in your motor.
Old Nov 27, 2004
navyedoc's Avatar
navyedoc is an unknown quantity at this point
if you wanna go cheap fuel setup. get a old vafc or safc and bigger injectors and don't go over 7 psi. and its under 350
Old Nov 28, 2004
dezod's Avatar
7thgen Power Maker
bump for good info
