Intercooler Piping
Old Nov 16, 2004
abmerop18's Avatar
Jam out with your clam out.
Intercooler Piping
im about to go hit up summit racing and get my intercooler piping for my turbo kit and was wondering what bends i will need? i have an LX, so i will be running the piping up both sides since i will have room for it. i am getting the 2.5" piping and already have a chargepipe, so i just need a few pieces. i know i need 2 "U-bends", but what other pieces will i need? i am just gonna take it to get welded up then powdercoated when i am done. thanks for the help.
Old Nov 16, 2004
dezod's Avatar
7thgen Power Maker
2/5" is might small. Your turbo is going to be the size of peanut then.
You mean 2.5"?? I'd recommend buying all u-bends and cut, hack and weld as you need. U-Bends have every bend available to make what you need. Take it from experience.
Old Nov 16, 2004
BIG's Avatar
BIG
do you have a FMIC with both ports on the one side or one on each?
Old Nov 16, 2004
abmerop18's Avatar
one on each side. and thanks for that correction about the piping dezod
dezod - you really think that all U-bends will work? how many should i get if i already have the downpipe? and 2.5" piping is plenty good, correct?
Old Nov 16, 2004
dezod's Avatar
7thgen Power Maker
I'd say 8-10 bends or so should be fine for the charge piping. 2.5" will support like 500 WHP as far as air velocity............it is more than enough. You may actually be doing harm by going that large of a diameter. Air travels up to a certain velocity, then actually creates turbulence in it's travels anywhere after that point. That turbulence causes poor air flow, which inhibits performance.
Old Nov 16, 2004
abmerop18's Avatar
i already ahve a charge pipe that is basically the long portion of a CAI with a BOV flange on it. so i dont think i need many pipes. i was thinkin more along the lines of like 3-4, but i dont know
Old Nov 16, 2004
tfnaaf's Avatar
BLDNPSI Mod
See if they have J-bends, they are a U-bend with one leg longer may be benificial. Also have you figured out what your doing for winshield washer bottle? I've been searching for something small and compact to fit over by the battery.
Old Nov 16, 2004
abmerop18's Avatar
i wont need the windshield washer bottle. i will only be driving in the summer and i almost never use it in the summer.
Old Nov 16, 2004
abmerop18's Avatar
can anyone confirm for sure how many u-bends i will need if i already have the charge pipe and downpipe?
Old Nov 17, 2004
abmerop18's Avatar
i guess no one knows
Old Nov 17, 2004
civicskater's Avatar
Chicks dig my scent
i ordered 5 and used about 4 on my first setup...works good, bought all mild steel U bends, cut, welded, then powdercoated them. Its kinda fun like a jigsaw puzzle
Old Nov 17, 2004
abmerop18's Avatar
did you use 4 u-bends for everythign including the charge pipe or is that excluding it?
Old Nov 17, 2004
Chicks dig my scent
yep used everything, i used a 90 degree elbow after my charge pipe to the throttle body until i got my intake manni and throttle body
Old Nov 17, 2004
abmerop18's Avatar
ok thanks man. ill hit up summit racing this week and get the 4 u-bends then
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Cam Diaz
Sep 29, 2015 07:17 PM
michael0219
Sep 1, 2015 10:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
