Fitting Problem...
Old Nov 9, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Fitting Problem...
HI im having a problem with the oil feed line for the turbo, it is leaking oil forn the turbo side, and i dont know if it is the line or the turbo, but here the deal...
I had lost the fitting that came with the turbo and had to replace it, i dont know if it was the correct size but i used a 1/4 inch fitting, and it worked (on a T3 turbo), the prob is i dont know it it is cause its a 2 piece fitting, or because the tip where the feed line conects is not round....
what could it be???
Please help....
Old Nov 9, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Stupid question but ........ you did use teflon tape right?
Old Nov 9, 2004
Yes i teflon taped everything ( the fitting int the turbo,the straight part of the fitting into the L shaped fitting, and the line to the fitting...
Old Nov 9, 2004
civic01vtec's Avatar
even if the fitting is too small, it still shouldn't leak. You need to pinpoint where it is exactly leaking and go from there.
Old Nov 9, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
What kind of turbo is it?
Old Nov 10, 2004
T3, and it leaking from behind where you conect the line, the point where the line ends, and you screw it in...
Old Nov 10, 2004
Anyone know what size is the fitting that comes with the SF turbo, is it 1/4 NTP to -6 AN
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
carid
Sep 28, 2015 10:13 AM
rnaodm
Sep 21, 2015 12:42 PM
Dave Brabant
Sep 12, 2015 08:39 PM
