new plz help
Old Oct 27, 2004
kkk's Avatar
kkk
kkk has a little shameless behaviour in the past
new plz help
heylo all . i have a d16 auto.
i am runny Garrette T28 turbo with an intercooler. no mods done on fuel pump , injectors. only added a VAFCII.
currently i am running on 4 psi.
could anyone tel me till how much psi can i go with this stock setup?
secondly , ever since i added the VafcII , my car boggles and vibrates and somtimes shuts off when i start it in the morning (when car is cold).
is this due to less fuel or more?
thanx
Old Oct 27, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Idle has nothing to do with boost. When idle or starting the engine, it's running as it normally would run N/A (1 atmoshere)
Idle has not boost, no vac. So your injectors are spraying as much as they normally would N/A
I think you probably just need to adjust your idle cable. Seems like you're not getting enough fuel.
Old Oct 27, 2004
Boosting Daily
I hope you mean b16. I'd think the safest amount of boost to run on stock injectors would be something like 6psi, but i'm not an expert when it comes to fuel systems. I'd suggest upgrading your injectors and using E-manage to control it all if you're wanting to increase boost
Old Oct 27, 2004
Boosting Daily
and IMO, bad choice of a screen name
Old Oct 27, 2004
dezod's Avatar
7thgen Power Maker
Idle can be affected by the addition of turbo. It can become more rough because the turbo is operating outside of it's efficiency range, and also larger injectors can induce poor idles as well due to variance in size from the ecu is used to.
Idle has vac too btw. On our car, it is approx 20 in Hg on idle under most occassions.
Old Oct 27, 2004
Boosting Daily
/\/\dang, sorry, btw, i'm still a boost noob, haha
Old Oct 27, 2004
dezod's Avatar
7thgen Power Maker
No prob. Better to be educated than misinformed.
Solo Flow
Oct 4, 2015 07:52 AM
Luluharp
Sep 27, 2015 11:56 AM
jody501
Jul 10, 2015 11:01 AM
Myredjonda
Apr 14, 2015 07:00 PM
PeArlHoNdA
Mar 6, 2002 04:18 PM
