TSI Extreme Turbo kit Vs. SF Basic turbo kit
Old Oct 14, 2004
  #31
TheSmuggler's Avatar
Didn't someone just say that it could come with a T28BB, are you smokign crack, get that. It's the best of both worlds, a hybrid of t25 and t3 mixed together! A 28 would be perfect for what your trying to accomplish, and it's BB which is gonna make it spool hella faster than non BB's =)
Old Oct 14, 2004
  #32
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
/\/\true-ness. I have my sights set on the T28bb now, thanx
Old Oct 14, 2004
  #33
Boosting Daily
Originally Posted by futurersxswap
SF for sure man.. we have yet to see good track times from other kits.. tried and tested best kit out there... easy high 13s around 8psi...
that's probably only because not many people know about this kit evidentally. Crewchief ran 13.6 on TSI which is *gasp* 1/10th faster than you
Old Oct 15, 2004
  #34
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Originally Posted by EternalBlue_Vic
How much boost was Crewchief running?
I wanna say 13psi
Old Oct 15, 2004
  #35
exturbo6's Avatar
yeah i have a t28bb turbo waiting to get installed...i cant wait!! just need a lil more money.
Old Oct 15, 2004
  #36
Boosting Daily
Originally Posted by JetBlu01
I wanna say 13psi
Ouch. So i'm lookin at mid 14's with 6psi?
Old Oct 15, 2004
  #37
Damn that sucks, but then you gotta understand that kit was made to run that high amount of boost, you better throw on a ticker head gasket just to be safe lol. Damn thats high even for Fac. TC'ed cars
Old Oct 15, 2004
  #38
exturbo6's Avatar
whats a good head gasket to get to lower the compression? without doing that double stack ****?
Old Oct 15, 2004
  #39
Boosting Daily
it's all good, i don't mind being boosted and slower than other boosted vics. I just want boost!!!
Old Oct 15, 2004
  #40
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Originally Posted by dezod
Regardless of turbo size, the auto tranny is not going to hold or perform any better no matter what size turbo you buy. If it is T3, T25 or T3/T4. The auto tranny is a power eater...Plain and simple. The driveability is actually quite fine on a T3. It drives like n/a in light street mode driving without building boost unless you hit it a little more and want boost to build. If you have gobs of low end and can build boost while barely doing anything, then your not going to have a tranny left after a few months anyway. Then you may have just as well swapped to 5 speed and got the T3. Not to mention the fact you will need more boost pressure on a smaller turbo to make same power that a larger turbo makes on less PSI.
7PSI on a T25 does not equal 7PSI on a T3.
Edit: Plus we are running a fully functional catalytic converter, which robs quite a bit of power as well.
100% agree with Dezod, the T25 is a joke of a turbo. That thing is not capable of what you guys want, its made for quick spool and little power. If your gonna spend all that money boosting the D17, just do it right so your quick.
My opinion
Old Oct 15, 2004
  #41
Boosting Daily
/\/\ whould you consider the T28bb as doing it the right way?
Old Oct 15, 2004
  #42
truehonda's Avatar
its ok I guess, but you will never get what you want with any of those mitsu turboes. They are small and flow low CFM but rotate so fast that they produce an equivilant equation of moving air. THe only thing is, the volume is very differnt and their efficiency is horrible!
Old Oct 15, 2004
  #43
exturbo6's Avatar
well maybe to prove this whole point on which is better and which one isnt..does any one have time slips or dyno sheet to prove anyhting besides word of mouth??
Old Oct 15, 2004
  #44
truehonda's Avatar
guys, I sell the SF kit, I have gotten rides in it multiple times. It has torque, and large turbo has torque. Dont forget that its not only about how fast you run the 1320, its also about how the car drives. If you have to beat the death out of it to run possibly 13's--- then IMO its not worth it. Catalyst ran a 13.6 on 11psi and alchohol wich ive gotten a ride before in (Similar car) and its not straining. the only t25 experience ive had in a honda was a T25 kit in a d16z6 SOHC, which was horrific to watch as the motor hardly pulled.
Old Oct 15, 2004
  #45
truehonda's Avatar
im not bothering anymore. get what you want, just dont get upset when you can break 14's if that t25's life depended on it.
Why do you think Dezod, Stafford (for 7thgens) use T3 and make power? Why does no one else but good ole "greeeeeeeeeeedy" use t25 and t28 -- because they are not worth it in long run! its a cost effective method to save money.
Old Oct 15, 2004
  #46
Well, I think he just wants a little more bower, but then you gotta remember eddie that if he slapps on anything larger than a 28 he's gonna get some lag, mabye really bad. I was kinda under the impression he wants around 200 whp.... so that could be a t28, but dont cast out the 25 yet bro, it's quick spooling makes it formidle on a daily driven street car thats not trying to set any records. Check out the rate it puts down from an SR20 blacktop =)
Old Oct 15, 2004
  #47
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
You have to take into account that not all T25's, all T28's, and all T3's are the same. I can make a T28 spool up late, and i can make a T3 spool up quick. You have to remember there are trims for the compressor and turbine wheels, .AR ratings for the compressor and exhaust housing, inducer and exducer sizes, and other aspects of each turbo series. All of these play a part in spoolup times.
Just remember this, a normal T3 Super 60 is still a T3. And the turbo off of a volvo is still a T3. There are drastic differences between the two. But, they are both still T3 series turbos. This goes for all turbos. You cant judge a book by its cover, nor a turbo by its designation.
Old Oct 15, 2004
  #48
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Great info Mike
Old Oct 15, 2004
  #49
Catalyst's Avatar
Why thank you. :takes a bow:
Old Oct 15, 2004
  #50
truehonda's Avatar
Yes, thanks Mike, makes me look dumb, but im happy you where the one that did it
Old Oct 15, 2004
  #51
Catalyst's Avatar
haha. sorry eddie. I am just speaking for you. think of me as an extension of yourself.
Old Oct 15, 2004
  #52
CarboyHieu86's Avatar
CarboyHieu86 is an unknown quantity at this point
TSI would be my pick, im starting my turbo fund too and im going with TSI rather than SF cuz of their reputation
Old Oct 15, 2004
  #53
Boosting Daily
Talking
cool deal. When ya think you'll have the money? I'm starting now too and my financial projections are placing me boosting sometime in mid febuary to late march
Old Oct 16, 2004
  #54
WhiteCastle's Avatar
Originally Posted by drjvic04
I like the numbers that Dezod is putting out. A lot of people doctor up numbers when they do dynos to get the wow factor. Some people fall for it. Im not saying that SF did that. I just mean that when I saw Dezod's #'s I didn't automatically have to adjust for the BS factor you see in so many kits today. I like that, it lets me know that they're on the up and up. If the numbers aren't what you want keep in mind that this on an economy car with a catylitic converter(by the way a lot of people dont do dyno runs without some sort of cut out or test pipe). Don't hate on the kit, just because this guy respects you enough to give you real results.
Dezod any valve body mods in the future for the VIC?
hes putting out only 145whp....thats numbers?
5 grand for what 45whp gain at 7psi? estimate... jesus k20 is 200hp and costs that much putting down a non laggy 180whp?
my god I know auto sf kits putting out 185whp(boostedciviczex) and this kit in works got that damn t3 lag to 3500rpms its a regular civic...
his kit was never good at numbers only thing went for it I will be honest in my opinion is street legalness.
in all honesty the best kit on this site despite some quality control issues is the SF kit. It will smoke wrx seen it in action...
I still stand by recomending all autos to use t25bb though because you'll regret being a "civic" na car until the 3500 rpms than by time you start feeling the power never get full advantage of it.
ohh a damn good turbo is the hks t28bb with ceramic blades catalyst
Old Oct 16, 2004
  #55
I hate Catalyst, he got what we argued for like 5 posts in 1 shot =*( lol
Old Oct 16, 2004
  #56
Havok2k1's Avatar
Wicked Pissah Admin
http://www.7thgencivic.com/forums/sh...d.php?t=142883
Old Oct 16, 2004
  #57
LOL, the 28 dosent apply to that =*( cuz it's already been changed =*(
Old Oct 16, 2004
  #58
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
whoever commented on my line that no other kits have made good numbers... yeah, looks like the guy has me by a tenth, with me running a 2.252' on bald tires, AND 4 LESS FREAKING POUNDS OF BOOST!!!! lol... 13psi vs. 9psi (me) and he only runs .10 better than me??? LOL.. not to mention we dont know where in the 13.6s he was, i was 13.71, so in theory he might only be .02 faster than me with 4 more pounds of boost,... that is just so hilarious to me... my bald street tires vs. his probly dr's atleast and 4 more pounds of boost and he gets me by 1/2 a bumper.. LOL
Old Oct 16, 2004
  #59
I love futre, he makes me happy... =*( BIOTCH
Old Oct 17, 2004
  #60
CivicSouldjaEX's Avatar
I don't like the bonnet look. I like the way it goes into the throttle and where the filter is on this kit. I want my kit to look like this, except another color.
