K20a3 or turbo?
Old Oct 13, 2004
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
K20a3 or turbo?
I just wanted to get everyones opinions on this because I have been thinking turbo but after reading a few post on the K20's I've been thinking. I'll probley go with the K20a3 but I can still go with something better not sure though. Thanks
Old Oct 13, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
hey if you have the money, go K20 A2/A3 for sure. Even down the line you could go turbo on that engine. But if ur money is limited/you dont know nothing bout swaps. Go for the turbo. Assuming your 7thgen. You can check out the SF kit for our cars, or the TSI kit from turbokits.com. Dezod is coming out with one mid April 05. So basically do what you can afford.
Old Oct 13, 2004
jttegx's Avatar
OMNES AD UNUM
if you go with the turbo, you wouldnt have to worry about toggling your ecm(ecu?), exhaust, relocating battery, o2 sensors, etc all that electrical junkie. with turbo, its just bolt on and prob relocate battery?
Old Oct 13, 2004
cbaer543's Avatar
yeah I don't really have the money. It will probley take me a year (and about 5-6 mon. for turbo) but if it is better in the long run then I might go for the swap. But one other question is are the specs.
K20a- 200 HP type r
K20a3-160 HP SI
K20a2-210 HP type s
An idea I also thought of was would the 6 speed tranny from the type s work with any of the other K20's? It may not be worth it but it was just a thought that came in to my head.
Old Oct 13, 2004
ImportRacer2123's Avatar
K20 Member
I say buy my kit
Old Oct 13, 2004
cbaer543's Avatar
see that is a great deal but the money isn't there not until 5-6 months hopefully
Old Oct 13, 2004
doubledeuce2k2's Avatar
k20a is 220hp JDM ITR engine
k20a3 is USDM SI/RSX base, 160hp
k20a2 is 02-04 USDM RSX-S, 200hp
new 05 type s engine is 210hp, i'm sure real hard to find right now.
k series 6 speed would work on a motor that normally doesn't have a 6 speed, but w/out other upgrades would be kind of a waste. IMO. of course, there are engines in that power class that come with a 6 speed (160hp Mini cooper s and 170hp Ford SVT Focus come to mind).
Old Oct 14, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
turbo is awesome man... just my 2 cents....
Old Oct 14, 2004
gh0st's Avatar
TAQUITOS!!!!
it seems to me that a swap is more easily taken care of after it's done than a turbo (tuned, upkeep, etc). but then again i have neither, this is just my observation...don't hate me turbo guys, i still like your cars
Old Oct 14, 2004
civic01vtec's Avatar
swapping a a3 is a waste IMO..........if u swap then go for the a2
turbo is faster than any swap, but in the end, it will cost you more than any swap.......trust me.
Old Oct 14, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
if u can afford it get the type r.. im half way there to getting a type r
Old Oct 15, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
a BOOSTED A3 makes good power though
Old Oct 15, 2004
djmota's Avatar
so does a boosted d17. The extra money spent on boosting the A3 could have went to a better a2 or A swap, and have all motor dependable horsepower and a 6 speed. If you swap go a2.
Old Oct 18, 2004
CarboyHieu86's Avatar
CarboyHieu86 is an unknown quantity at this point
im kinda in the same position, either i do the swap or turbo the car?!?!?! maybe the swap since i got the hook ups
Old Oct 19, 2004
import2nr's Avatar
awd pwnz j00
they are both great and either one you go with you will love. but heres my $.02 go with turbo. you can get a turbo kit for around 3k then build your engine for another 3k or so, and then have great numbers. with the swap its prolly gona be around 6k and you only have at the most 200hp. so you figure 6k for either one and i think youd put down more with the turbo... also a factor to consider (for me anyways) is that if u blow a D17 theyre cheap, another K20 would be a lot.
Old Oct 19, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Turbo it man
Old Oct 20, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Why spend 4000-6000k on a turbo kit for the D17 when you're only gonna max out to around 250 whp before you have to tear it apart and do internals? I personally would much rather spend the same amount on a swap and have a much better baseline of power to build off of rather than the weak, tried and true sohc.
Old Oct 20, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
didn't you JUST install an sf turbo not that long ago??
Old Oct 20, 2004
250whp is a lot for a FWD car. i bet you give most people 150whp civics and they'd have a blast. there are still pros and cons to both.
Old Oct 21, 2004
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
If you think (and you're right) that 250 is a lot in FWD what about that nut on the cover of Sport Compact a few months ago with the 455-HP vic? He said he could hardly make the car catch in first gear. Me personally, I don't care....I'd rather be all show and no go and have the plates to prove it: my license plates would be NOTFAST.
1,000th post
Old Oct 21, 2004
By the time I'm done modifying my civic, which will probably be years from now, I'd like to see 300-400 whp under my hood. 250 whp is not quite enough power and is not really worth the money spent to achieve it. The higher horsepower numbers will be easier to obtain with a K series and probably will end up costing just as much if not just a little more. Its just a better investment I think if you're serious about making some huge power.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
