auto sf turbo help
Old Oct 9, 2004
deciuss's Avatar
Boosted Auto
auto sf turbo help
ok i need some help here guys, we had every thing on i meen every thing but the oil pan off to tap it. we could not get it off it looked as thow you had to take the acutal tranny off to get the bolts off for the rest of the oil pan to drop it down.
how did you auto guys do it? we had to take every thing back off other then the fuel pump and the actual intercool so i could drive back home.
Old Oct 9, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Is it an EX? If so there are a couple of brackets that brace the tranny that you remove. Its nothing major, just a couple of bolts. If it still doesn't move, tap it with a rubber mallet until it comes off. The sealant they use at the factory sticks pretty good.
Old Oct 9, 2004
deciuss's Avatar
Boosted Auto
we where going to do that but then there was some spring for the shifter that would come with it he said so we said f it surg
Old Oct 9, 2004
Bring it to me. I can have you up and running in no time.
Old Oct 9, 2004
deciuss's Avatar
Boosted Auto
are you located in WI?
Old Oct 9, 2004
No, but if you're willing to drive down over a weekend I'd be more than happy to help you out.
Old Oct 9, 2004
deciuss's Avatar
Boosted Auto
hehe im just gona call a shop i know and fork over some cash sucks but i orderd the kit may 18th i want this thing on haha
Old Oct 9, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Dude, I can help you with it. Just pm me and let me know when. No use pissing away money when you got a member local that used to have the kit.
Old Oct 10, 2004
gotti's Avatar
Dude....i did the whole kit myself...@ the age of 17.
All u gotta do is remove all the bolts. Then you remove the 2 or 3 tranny bracket housing things off. I also took off the black protector plate thing, it just seemed like it was in the way. Then you gotta pry on that thing until you break the seal. I mean, you really have to pry it. I put all my weight into it with a crowbar and finally broke it.
You just have to use some ***** when you're doing it, don't feel like you're going to break it. Just give it everything you got and that sucker will break lose.
Old Oct 10, 2004
civic01vtec's Avatar
lmao, popping off the oil pan was the easiest part.
I thought futurersxswap was gonna help you
Old Oct 10, 2004
deciuss's Avatar
Boosted Auto
lol he did but he never did an auto sf kit. started at around 6 found problem at around 10:30 ish both said the f word for about 15 minits then he started the long process of putting every thing back on that was stock i still feal bad that i was not much help i was just overwelmed by the whole thing.
i was like a dear in headlights.
i think my gf did more work then i did she cut the whole front bumper part off and took off the front bumper plus cleaned up ect ect
Old Oct 10, 2004
Did you manage to get it installed? If you haven't yet, I'll do it for free if you're willing to make the drive.
Old Oct 11, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
crap.. I should have taken pics of what you have to do. I was kind of confused at first, but really, everything is just held on with bolts. there's 2 14mm, several 12mm, and several 10mm bolts. in the end you should take off 3-4 brackets, put the shift lever in 2nd gear, take off the bolt that's attached to the shift lever cable (the bronze piece that goes into the transmission-- there's a locking tab thing you have to pry up with a flathead or something), then remove the black inspection plate.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Sep 27, 2015 11:33 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
