Dumb Fit in Hole Turbo Thing-A-Ma-Jig
Old Oct 2, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
okay... take a look at this
okay... imma try and explain this the best i can so bear with me.....the top silver line is a fitting that runs the oil feed line.. then theres that middle adapter in the middle which connects to that oil feed line... now that middle silver adapter goes in to that bronze adapter which fits the turbo housing.. my question is... the bronze adapter fits into the housing very well... and the silver apapter fits into the oil line very well i might add.. also used teflon to make sure a good fit... but the thread between the bronze fitting and silver middle adapter dont fit.. holes are same sized but different thread... so what i did was forced that bitch into there to make its own thread... now the problem is now it doesnt leak.. but after driving a while it starts to leak... so anyone know what the proper sized fittings would be and sizes??????
also u think if i just use some sealant or some honda bond or some jb weld i could just put over the forced area to make it fit???
by the way.. the car is done and painted and heres what it looks like
it went from this
to this
then finally to this
Old Oct 2, 2004
i think i need a new hood
Old Oct 2, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Is that fiber glas or thane?
Old Oct 2, 2004
fiber... but its not a VIS.. some cheap stuff i bought.. but then again u cant even see it at night unless there a reflection
Old Oct 2, 2004
opto_isolator's Avatar
You may have an adaptor for on older civic. The older civic's used a different fitting, something called a BPST fitting, which has wierd threads....Make sure you have standard NPT threads....that might be your problem.
Old Oct 2, 2004
gotti's Avatar
that FMIC looks soooo scary.
very sexy
Old Oct 3, 2004
very sexy
is it really?
Old Oct 3, 2004
gotti's Avatar
yeah, especially with the 2 pipes exposed on the sides.....wow.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
EM_WON
Jul 22, 2015 06:49 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
NoobyKid
Jul 13, 2015 07:53 AM
stvpagn
Jul 9, 2015 09:59 PM
