turbo effects?
Old Sep 23, 2004
jyoung's Avatar
jyoung is an unknown quantity at this point
turbo effects?
Anyone know what the long term effects of putting a turbo on a stock 01 auto ex would be? Not sure if I would be pushing it close to blowing the engine, or if I could still use it as a daily driver.. It has about 38000 miles on it right now, I drive it probably 20miles a day, maybe 35 now that I'm moving further from work. Any info would help, thx.
Old Sep 23, 2004
nickm748's Avatar
I dont think there will be any damage if ur running low boost and You have proper cooling. Of course things will wear and tear alot faster because ur probly going to be toolin on it because of the turb.
Old Sep 23, 2004
bluestreak's Avatar
bluestreak is an unknown quantity at this point
Turbo's kill engines from my experience. Even factory turbo'd cars usually only make it to 90K before you've got problems.
Old Sep 23, 2004
TurboDreamZ's Avatar
Super Member
TurboDreamZ is an unknown quantity at this point
eh.. i dont think itl be that bad. highway driving will just bring al that cold air rite to ur intercooler. eh thats alot of driving.. lol
Old Sep 23, 2004
Changu-San's Avatar
Mr. Clean
when will someone make a supercharger for our cars? turbo is nice and you'll probably exerience problems when you're around 100k miles, but its fun...by the way my 91 mr2 turbo has 135k miles and still running strong on the same motor.
Old Sep 23, 2004
jyoung's Avatar
thanks for the info, doesn't sound like too bad of an idea, i don't have nearly enough for the turbo yet (probably wait on the ol' tax check ), are there any specific brands you guys might recommend? I live in indy so everything is spread a part, given the 15mile drive to and from work, and the weather of course is generally a little bit of everything, heat, snow (salt ), rain, etc... but this still seems a lot more affordable and reasonable then the k20 swap, if I had the k20 money, I suppose I would probably just buy a new car heh.
Old Sep 23, 2004
Got Boost???'s Avatar
My mazda had 116,000 miles on it before it went. I came from the factory running about 8 psi and when it went it was pushing 20 psi.
Boost is boost no matter how you go about making it. Having a supercharger running 15 psi is no more reliable than a turbocharger running 15 psi.
The only way I see a supercharger being slightly more reliable is that the boost is more fixed than a turbocharger. My mazda blew because the boost went past 25 psi when it should have been running 20. You won't find the boost on a supercharger changing much. But on the flip side if you ever want to increase the boost on the SC you will need a new pulley.
SimpleUser
Apr 24, 2021 02:54 AM
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Raiool
Oct 1, 2015 10:42 AM
justcruzin125
Aug 11, 2015 09:09 PM
