having a driveshaft issue with my k20a civic
Old Sep 18, 2004
1llmatic's Avatar
1llmatic will become famous soon enough
ok...
This is my scenerio:
I swapped the JDM K20A motor into my 01 civic sedan.
I used GSR driveshafts for the initial swap.(one of HASPORT's options for driveshafts)
after a few weekends of racing and launching the car...
left driveshaft popped out.
so i disassembled a set or RSX type R driveshafts and used the GSR heads (one of HASPORT's options for driveshafts)
The right driveshaft was too long and the inner boot ripped after a quick test drive.
Decided to get another set of GSR driveshafts...drove about 1/2hr and the left driveshaft popped out again.
My question is...what shaft should i be using?
The only other options i have are HASPORT driveshafts or CIVIC SI driveshafts.
Options?...i'm wondering if HASPORT could give some feedback if they are on this board.
thanks
Old Sep 18, 2004
C2i0v0i1C's Avatar
SuperMODrizd
ever thought of callin them and asking, also there is a member that gets on here that is an employee there, i think its BRIANG
Old Sep 18, 2004
tcostello's Avatar
tcostello has a little shameless behaviour in the past
Check out the Driveshaftstore.com. Let them tell you what you need.
Old Sep 18, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
use the SI axles.
Old Sep 18, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I heard SI axles are best.
Old Sep 18, 2004
SODJAZERO's Avatar
sorry 02 SI and up
Old Sep 18, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i was thinkin www.driveshaftshop.com
ur suggestion takes u to wholesaleimportparts
Old Sep 19, 2004
Jodster's Avatar
Post Whore General
Just get some 02-04 SI 4 lug axels and you will be fine.
Old Sep 19, 2004
Hawk's Avatar
You boost, I-VTEC
He's alittle more than a employee he owns the joint
Yea use 02-04 EP SI axles.
Old Sep 19, 2004
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
actually ithink the 02-03 si axles the 04 is 5 lug.. I had the same issue. The Gsr one will work on the passenger side oddly enough but like poppin ou tof the driver side. When i had this problem. I just got the Si axles.I was to lazy to do the passenger side so i just did the driver side since that was the problem. oh and Fyi the locking ring on ure gsr axles dont lock in its proper place thus poppin out under load.
Old Sep 19, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i didnt dig that deepp into him, i was close though
Old Sep 20, 2004
1llmatic's Avatar
.EP axels work with no problems wutsoever?....
ok i will try them....thanks a bunch guys
Old Sep 20, 2004
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
no no no, our cars is not meant to hold so much torque, so get the si axles and ur good, and change the bushings, and its 4 lug
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
McD
Apr 29, 2015 03:50 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
civic_gt
Apr 19, 2015 08:15 AM
skywalker
Nov 8, 2001 05:04 PM
