WTF?! Catalyst has 304 HP and 276 ft/lbs of torque?!?!?
#31
Skyline R33
Rep Power: 0 All I can say about all this is that my SF Kit made 231whp on 10psi using methanol injection. NO head work, no T/b, just stock everything with a FMU for fuel management. I have a little intercooler and my tuning isn't that great.
Catalyst, I put on a DH head and it feels like I lost 25whp. What would cause this? My narrow band O2 still shows rich. He ported the crap out of the exhaust. Would that cause a loss of power? DH-Josh sent me a cam, I/M and T/B. My shop is saying that the short runners on the I/M are only good for higher RPM and will hurt a low reving D17. I was also told that the 74mm Throtle body is bigger than the charge piping on my kit and it will not help unless I get bigger piping. The shop also questions the Cam and told me a turbo cam (overlap) is actualy not good for a D17.
Could you shed light on these problems? At this point I am ready to part out the hole car and say screw it. The only thing that work so far is your kit. Everything else has been problems. If you can help and give advise to a rooky it would be greatly apretiated.
#32
New Member
Originally Posted by Catalyst
yea, i used a squirrel caged fan on my intercooler while dynoing. Basically like a giant swamp cooler.
On 15-16 psi i have air intake temps of about 110-115 degrees. And seeing its summer time in the desert, those are pretty low.
I am using Methanol-water mix. Close to a 90-10 mix. I use a split-sec programmer to fine tune everything. Its like an emanage.
Engine Mods
Garrett T3 Super 60 turbo trim
SF equal length manifold
SF 2.5" dp
SF PFM Fuel System w/ alcohol injection (plan on running methanol)
SF Intercooler
SF Mandrel Intercooler Piping
Turbo XS Blow Off Valve
ACT Clutch
NGK Platnium Plugs (denso IK22's on way)
Custom 3 inch exhaust....no resonator, no cat
Goldline 1.75 drop
Koni Yellows
Greddy Profec B Spec II
Greddy Full Auto Turbo Timer
Revo Short Shifter
also coming soon are Energy Suspension Motor Mount Inserts....give me a guesstimation....
#33
Originally Posted by JetBlu01
damn....yeah I have a 5 gallon of methanol in my garage as we speak...I'm waiting to get some DensoIK22's plugs then I'm running Methonal instead of the alcohol....u RECOMMEND 90-10 mix? cool...hope I get some decent #'s...on 10-11psi...what can I hit at the track...here's my setup
Engine Mods
SF 2.5" dp
SF Intercooler
ACT Clutch
Goldline 1.75 drop
Koni Yellows
Revo Short Shifter
Engine Mods
SF 2.5" dp
SF Intercooler
ACT Clutch
Goldline 1.75 drop
Koni Yellows
Revo Short Shifter
Depends on how you can DRIVE-
You can get a 14 second pass in a viper if you dont know what your doing
#37
Originally Posted by 1320Racing
^^ Need to work on 13.9 screw 14's
YEAH
YEAH
#39
Premium Boosted Member
Rep Power: 302 Bout the 14.3... you can easily get that with 9-10 psi... at 7.5 I ran a 14.5, then consistant 14.6 at 95-96mph... That was with a body kit and only 2.2 60' times...
#40
New Member
Rep Power: 0 naw I have a 2dr EX 5spd manual...okay 14.3 first then we'll go from there....btw congrads on your dad's truck...what do u run btw?
13's would be nice though...I plan on getting the VAFC II here in a few days and get it tuned so we'll see....thanx guys...okay back to topic
#43
First to spool
Originally Posted by deciuss
why does every one say autos are slower then manuals, a few auto tranny mobs and you can get more power and faster times outa them. no one can shift as fast as a computer
Plus the usual problem of the automatic transmissions not being able to hold the same amount of power as the manuals. Manuals also have a lot less parasitic drag on the power output to the wheels. Manual transmissions lose typically 15%, while automatics lose closer to 25%.
#44
Rep Power: 305 I got full internals done into my engine, pistons, sleeves, head, valves rods etc, an getting a custom made turbocharged as we speak and I don't think I'll be pushing it to 14 psi or anything to that fact.
Is just too much $$$ and time to waisted at the dyno and at the garage repairing the dam thing instead of enjoing it driving.
I'll be just happy to drive my car every day for the next 5 years without any major incidents or brake downs.
I know that a drag / racing cars go thru many engines and tranies but that's what they do profesionaly, race.
Some ppl just look at performance in different ways.
Ether you build a racing car or street car.
I handed to you guys though for pushing the envelope and showing that it can be done.
Good luck
Good luck
#45
#47
im saying a built auto tranny with an electronic shift kit ect and an upgraded touqe converter (spelling)
lol......considering that only .001% of ppl with autos do this....... m/t > a/t
#49
New Member
#50
7thgen Power Maker
1 Post
i dont see why they dont rebuild kit 400 shift kit 400 upgraded tq converty 500 and you have a kick butt auto setup.
thats my xmass project
EDIT: If your gonna spend over $1300 or so, why not convert to 5 spd?
#51
Originally Posted by dezod
AUTO eats power. So much is lost in that tranny.......take it from experience.
#52
and u dont think your mods are pushing the envelope
But my intentions are to build a strong motor that will last last long time under reasonable amount of boost.
I'm talking 8 to 10 psi.
No reason boosting that much or over on a stock internals.
Even under 6 psi, it will be year tops, before you end up having problems.
Our engines are not made to boost the are made for economy and relability.
#53
yeahup I do,
yea well im going on my second year boosted at 12psi ON stock internals.
so stop talking out ur ***.
u know what assumtion does right.
#55
Rep Power: 288 Speaking of transmissions - Has noone thought about the internals of OUR 5 speeds?? There are currently no aftermarket internals for our cars yet (differential anyone?). I wish quaiffe would make one, but hell - everyone is focused on the damn K20....
#57
Originally Posted by HyaBoosta
^^ exactly. Why wear flip flops if you got no toes?
#58
Rep Power: 274 yeah didn't someone post that the d16 tranny will bolt on to our d17's? If so then wouldn't we be able to build the d16 tranny and drop it on. It would change the gearing of the car but would this be an option?
#59
7thgen Power Maker
1 Post
i dont want to learn stick i enjoy driving but just being able to put in drive and go.
5 spd is very nice to be able to hold each gear to the optimal shift point. This is not possible in the 4spd auto tranny.
#60
congratulations
