Custom Turbo setup--interesting
Old Sep 8, 2004
halflife's Avatar
halflife is an unknown quantity at this point
I was at a shop by my house that I have bought alot of stuff from the owner in the past. They just opened up partnered with a muffler / exhaust shop and are doing custom turbos. I asked them about the manifold they would use if they did my car. They never did one before so he said he would research what was out there. Told him there was not many choices then he told me this.
He said that on several civics and other hondas they had used the stock header or aftermarket one and just modified the flange or something at the end to attach the turbo and pipe everything back from there.
I say a pic of this on one car and it looked good. I know there is a company out there that makes remote turbos for trucks and camaros.
Basically he said it would save a schitt load of time and money by using the stock header and just modifying it.
What do you all think about that approach?
Old Sep 8, 2004
abmerop18's Avatar
Jam out with your clam out.
dont do it. no header is gonna be as good as any turbo manifold. its not gonna have big enough piping, the welds are gonna be worse, and your probally gonna have major clearence issues with the turbo and wastegate
Old Sep 8, 2004
HyaBoosta's Avatar
Sounds like a great shop. Are they going to custom make you a BOV and super glue a kazoo on tothe PVC IC piping?
Old Sep 8, 2004
civic01vtec's Avatar
bwahahahahahah.............that is fvcking great. I am seriously sitting here LMFAO
but yeah........steer clear
piping is wayyyyyyyyyyyy too small
Old Sep 9, 2004
AllEyEsOnMe's Avatar
AllEyEsOnMe is an unknown quantity at this point
What shop is this? Im guessing RCT in college point.
Old Sep 9, 2004
prototype's Avatar
x-factor
dont do it.....go with the hks manifold its only like 200 or something
Old Sep 10, 2004
ImportRacer2123's Avatar
K20 Member
**** the HKS one i have it and I wish I would have gotten a T3 manifold w/ a T3 turbo as well.
Old Sep 10, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Why is this? Not enough power from the T25?
Old Sep 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
What turbo are you running? I thought the T28 was good for like 300hp ?
Old Sep 11, 2004
yes, but the t25 flows less cfm's than a t3
Old Sep 12, 2004
Got Boost???'s Avatar
Don't do it!!!
Alot of people are under the impression that the turbine wheel is spun by the flow of the exhaust gas, like blowing on a pinwheel. This is not 100% true, while the physical movement of exhaust gas accounts for SOME movement in the turbine wheel. The majority of the movement of the turbine wheel is from the temperature.
Thermodynamics 101 - As a hot gas enters a larger area it will expand rapidly (the hotter the faster) to fill the new large space. As the hot gas leaves the turbo manifold and enters the turbine housing it expands very quickly. This is what makes the turbine spins. Moving the turbo farther away from the engine allows the exhaust gas to cool, thus it won't expand as quickly and your turbo will spool very very slowly regardless of the size of the turbo.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
HondaGuy7
Feb 22, 2016 01:00 PM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
