RPM lost
Old Aug 30, 2004
yourinmyw0rld's Avatar
RPM lost
sup guys everytime i shift gears let say at 3rpm my rpm goes down to 2rpm then da car goes. do u guys know what da promblem would be. Or when i redline da car it doesn't even chirp when i shift to 1st to 2nd da rpm just just drops down to 4 then da car goes.
Old Aug 30, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
uuuhh... isnt that how u drive the car... everytime u shift the rpms drop of course.. and when u sift the car goes forward... strang.. my car doesnt chirp when i go redline... nope.. dont see any problem there..
Old Aug 30, 2004
abmerop18's Avatar
Jam out with your clam out.
you dont want it to chirp. chriping is basically the tires spinning faster than the car is going causing a quick loss of traction which will in turn slow you down a bit.
Old Aug 30, 2004
Are you serious? That's how a car is made. And look you have a civic! It's not supposed to chirp anything.
Old Aug 30, 2004
tfnaaf's Avatar
BLDNPSI Mod
Old Aug 30, 2004
I have a turbo
Old Aug 30, 2004
it just kinda takes awhile to go when i shift gears.
Old Aug 30, 2004
abmerop18's Avatar
still, you dont want to chirp. it slows you down cause the tires just spin. and thats what you got your BOV for anyways
Old Aug 30, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
ok ok... just to try and help the guy out guys, and provide him with some positive info and questions, first off...
yourinmyworld- you need to explain the prob more thoroughly, because like xproductions said it's normal obviously for a car to drop RPMS in between shifts... if they aren't quick shifts they are gonna drop farther, do you understand up to this point? please elaborate more... and c'mon guys just try ta help the guy out to an extent...
Old Aug 30, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
lol nice one
Old Aug 30, 2004
Oh okay. Did you get the a/f tuned yet? My car has a pause between shifting, but it's an auto.
Old Aug 30, 2004
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
last time i checked BOVs had nothing to do with wheel spin there main and only function is to prevent compressor surge when the throttle plate closes in between shifts the pressure has to go somewhere and if it is not let off by the BOV then it will surge the turbo causing a severe stall in the turbine and it will have to spool again!
B
Old Aug 30, 2004
abmerop18's Avatar
B
i was saying he could get the chirping noise he was talkin about from his BOV so he should not be worrying about chirping the tires since that is bad anyways.
on a side note, lower tire pressure makes them easier to chirp
Old Aug 30, 2004
Handsonme's Avatar
Don't be a jerk. He is obviously asking for assistance.
What he probably is trying to convey is that the car lags in acceleration. The RPM needle goes down more than it should;instead of the car accelerating right away, the RPM decreases dramatically before the car even moves.
Old Aug 31, 2004
gearbox is not being a jerk... its just the way yourinmyworld phased it....
Originally Posted by yourinmyworld
......i shift gears let say at 3rpm my rpm goes down to 2rpm then da car goes. do u guys know what da promblem would be. Or when i redline da car it doesn't even chirp when i shift to 1st to 2nd da rpm just just drops down to 4 then da car goes.
look at the way he phrases it.... "he shifts at 3rpm then goes down to 2 rpm then car goes" .... thats typical driving right there... tell me by reading that u can tell me what the problem is??? also what car chirps??? if the tires spin then it squells.... if the BOV blows it makes a pshhhh sound.. unless ur civics are different than mines and makes a chirp sound when u REDLINE then i would like to what makes ur car chirp
Old Aug 31, 2004
Havok2k1's Avatar
Wicked Pissah Admin
This was doomed from the start........
sdraza1
Apr 6, 2021 08:51 AM
thaler4cuse
Sep 7, 2015 08:25 PM
dantheman42
Sep 4, 2015 01:10 PM
Bman2212
Sep 2, 2015 11:49 AM
2005seTO
Aug 18, 2015 12:45 PM
