Boost Problem
Old Aug 25, 2004
ImportRacer2123's Avatar
K20 Member
Boost Problem
OK well I have a problem with the boost gauge not reading vac and boost. It reads one or the other. but not both. People can see my setup on the Its Alive Thread. Can anyone give me some advice as to why its doing this?? Also the boost gauge only will go to 4psi. I tried my friends boost gauge and nothing same result so its not the boost gauge. all hardpipes are secure. no exhaust leaks either. Anyone want to take a guess as to whats wrong?
Old Aug 26, 2004
MadWheel's Avatar
Premium Boosted Member
are those vacuum lines properly sealed? i dont see any clamps anywhere...?
Old Aug 26, 2004
K20 Member
i will clamp them down tomorrow and see if that works are yours clamped?
Old Aug 26, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Do you have a enternal wastegate or external? Maybe the wastgate spring is set to only 4psi so thats why your guage is only going to 4.
Old Aug 26, 2004
K20 Member
I have an Internal Wastegatew that is set for 7psi and when i crank up my boost controller it stil stays at 4psi.
Old Aug 26, 2004
MadWheel's Avatar
How do you know it's set for 7psi if you've never made boost b4? or is this recent?
Old Aug 27, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Exactly what I was thinking....
Old Aug 27, 2004
K20 Member
ok everything is fixed im at 7psi now. thanks MadWheel
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Danofthebass
Jun 8, 2015 08:42 PM
Mike Garvey
Jun 7, 2015 07:25 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
