Essential harness' for e-manage?
Old Aug 11, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
What are the essntial harness's to buy for an e-manage for a boosted d17, injector and igntion...anything else?
Old Aug 12, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
You might want to grab the pressure sensor and harness too but it's not necessary to get up and running.
Old Aug 12, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
make sure u get the support tool too so u can hook it up to ur laptop!
Old Aug 12, 2004
MadWheel's Avatar
Premium Boosted Member
I'd get a greddy pressure harness. It'll def help you to tune by fuel a little bit better.
Old Aug 12, 2004
HyaBoosta's Avatar
the pressure harness tunes the fuel pressure?
Old Aug 12, 2004
dezod's Avatar
7thgen Power Maker
Greddy Pressure sensor & harness so you can tune off boost because once our stock MAP reads postiive manifold pressure, it will trigger a CEL and nothing will get accomplished. Get a Synapse Missing Link too.
Injector harness if you plan on adjusting duty cycle, larger injectors or controlling sub injectors.
Ignition harness if you like the ability to retard timing under boost.
Old Aug 12, 2004
HyaBoosta's Avatar
so the pressure sensor will shut down after a spike past a preset limit? or will it only throw the cel and allow it to continue?
Old Aug 12, 2004
Your Parts Guy
He meant "tune". The problem is that the ECU has no fuel maps for boost and the sensor helps you to tune for the positive vaccum pressure.
Old Aug 12, 2004
dezod's Avatar
7thgen Power Maker
Our stock MAP will throw a CEL, put the car in limp mode, and possibly shut down. The ML masks boost from the stock MAP. Since the stock MAP can't detect boost because it is out of it's parameter settings, whcih throws the CEL, then limp mode or even off.........the ML is needed to mask it and prevent that and make the MAP think the car is N/A. You can't run the car untuned as far as fuel under boost conditions. The GReddy Pressure Sensor is great for this because now you can tune off TPS vs ,Boost which is read by the GReddy Pressure Sensor.
Old Aug 12, 2004
HyaBoosta's Avatar
oh i got you now.
Old Aug 12, 2004
dezod's Avatar
7thgen Power Maker
oh i got you now.
Excellent
Old Aug 12, 2004
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
So If I'm using the turboXS dual stage and I switch boost levels will e-manage correct for the extra/lower boost without having to change fuel maps if we use the pressure sensor.
Old Aug 13, 2004
dezod's Avatar
7thgen Power Maker
No. Each map must then be re-corrected.
Old Aug 13, 2004
opto_isolator's Avatar
Actually if you have the Greddy pressure sensor it will correct for boost. You can change how the MAPs are referenced in the tool, which is why getting the pressure sensor is essential if you plan on running different levels of boost - it allows you to tune the whole thing better.
Old Aug 13, 2004
02fpcivic's Avatar
Thanks opto, I thought that would work. Just double checking.
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
