pumps and injectors
Old Aug 8, 2004
reytito's Avatar
pumps and injectors
yeah i searched but havnt found definitive answers so keep the flames away. so i wanna run 5 - 8 psi. rsx-s injectors plus stock fuel pump plus safcII. or should i look into a aftermarket fuel pump to accompany the injectors. what do you guys say? remember my goal is low boost...
Old Aug 8, 2004
civic01vtec's Avatar
the safc will work fine with the rsx injectors and stock fuel pump. If you wanna upgrade your in-tank pump, u will need to do a return fuel conversion which will run you around $800.
Old Aug 8, 2004
reytito's Avatar
but for 5 - 8 psi..tock fuel pump will suffice? wont be running lean?
Old Aug 8, 2004
not if you get it dyno tuned
I met speedracer32 at the MA meet and he has RSX injector with VAFC-II and is running 7psi untuned. Not recommend, but it isn't my car
But dyno tuning is the key
GritzNGravy
Aug 19, 2015 03:03 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
