Calling all Boosted 7thgen EX's!!!
Old Aug 5, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
I got my gauges, and SF intercooler mounted and I'm installing my turbo this weekend... but I don't have the time and money to get mine dyno tuned!
I'll be running 7PSI and i'll be using VAFC2 for alternate FMU any of you boosted guys running with VAFC/VAFC2, if it is dyno tuned? is it necessary to get a missing link even if I'm runnin low boost?
and also to all you guys who installed Apexi turbo timer for NA and Turbo Application, can you guys hook me up with a DIY? the one on this website is different from Apexi wiring, I'm just lookin for the O2 Sensor Wire on the ECU then I'm set... Thanks for the help!!!
PM me! thanks guys!!!
Old Aug 5, 2004
civic01vtec's Avatar
are u just using the VAFC-II for fuel management ???
Old Aug 5, 2004
Balut Eating Champ
I have the SF Fuel Kit and the VAFC2, I've heared some 7thgens was running with it with no problem...
Old Aug 5, 2004
so, u are using the vortech FMU also.
I know guns has one, PM him
Old Aug 5, 2004
Balut Eating Champ
^^^I wanted to get the VAFC2 setting for those who uses VAFC2 with their turbo!
Old Aug 5, 2004
Old Aug 5, 2004
Balut Eating Champ
^^^thanks bro! I PM'd him already and checkin out the settings for me
Old Aug 5, 2004
Balut Eating Champ
any other boosted guys out there?
Old Aug 5, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Does anyone know of any aftermarket head gaskets for D17 to lower compression slightly. I keep blowing Headgaskets at 12psi. Internals are fine. Just keep blowing pinhole size in the waterjackets inside the head.
Old Aug 6, 2004
Titleist71's Avatar
get a steel headgasket.....
Old Aug 6, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
dont get a steel heasdgasket, unless u like your engine to breath in hotttt air.
Old Aug 6, 2004
Titleist71's Avatar
^^^^?? WTF? If he uses a steel headgasket he will be able to support more boost. Hot air? Thats what the intercooler is for when u turbo..to cool the air down......stop posting at 1:44 am, tiredness isn't good for you.
Old Aug 6, 2004
Balut Eating Champ
tafak? come on guys focus here...
calling all boosted guys running 7psi and below and using vafc2....
anyone?
Old Aug 6, 2004
Get the Nippon leakless HG. And you should lower your boost setting fa real. If not, then i suggest selling your VAFC and buying a E-manage. The E-manage will allow you to retard your timing
Old Aug 6, 2004
guns's Avatar
Skyline R33
I am on my second Nippon leakless from Honda. Does anyone know of a company like Cometic that sales thicker headgaskets to lower compression? Some of yuo net junkys should know of a place for the D17.
Old Aug 6, 2004
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
cant you just double up on the headgasket?i recall someone posting that they did that to lower compression,but i forgot who.
btw pnoyster2k1civic i pm'ed ya.
Old Aug 6, 2004
C2i0v0i1C's Avatar
SuperMODrizd
that was me, just put two in, torque it to spec, then check it a week or so to make sure u havent lost torque, also cometic is copper i think, and i also think they can make u one
Old Aug 6, 2004
don't put 2 on unless you have a adjustable cam gear
Old Aug 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
well i guess i didnt take that into effect, but then again mine was planned and had alot of thought that went into it, and was built like that
Old Aug 7, 2004
Balut Eating Champ
hmmmm.... so 7psi will pop my HG??? tafak... I thought that will only happen if I'm runnin 10+PSI....
thanks for the pm bro! I pm'd you back!
Old Aug 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i doubt it
Old Aug 7, 2004
Balut Eating Champ
hey guys I still need the vafc2 settings....
and also I'm having problem with my TT it won't let me lock my car while it's running? what could be wrong? anybody know?
and do I need the missing link if i'm running low boost 7PSI???
thanks again!
Old Aug 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
hello u cant lock the car while its running its default honda thing
Old Aug 7, 2004
Balut Eating Champ
so why the *** do we need turbo timers for? I'll just sit in my car for 2mins and turn it off...
so everybody here can't lock their car while the turbo timer is on? there should be a bypass or something right? tell me that there is... anybody done this yet?
Old Aug 7, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
to lock your car while the car is running...when you get out, stick the key in the door and turn it...that will lock it....has keyless entry caused us all to forget that...we can still do it manually ....also, you dont need the vafc2 to run your car...the sf fuel setup is fine....i suggest taking it to a shop and use a wideband to tune it....or get the aem uego like me, and do it yourself....using someone elses settings are good....all of our cars are different, plus guns's settings are for 12lbs if that is the amount of boost that he is running....
Old Aug 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
WOW learn something new every day
Old Aug 7, 2004
Balut Eating Champ
I did tried that, but what I'm sayin is that, I can't arm the alarm system, at night the car being lock and the alarm system not armed is the same thing as it's not locked at all... man if I knew that the TT is a total crap I shouldn't have gotten the damn thing...
Old Aug 7, 2004
jwcardy's Avatar
turbo timer is nessecary....of course you cant arm the alarm when the car is running...when you say arm it at night, just wait until it stops, like when you are inside, then step outside and arm it
Old Aug 7, 2004
Balut Eating Champ
^^^I actually got it working... my alarm system have a 2mins default auto arm, so by locking the doors manually and after the engine stops, It takes 2mins for it to arm itself... hehehe I just got to excited and became to impatient and b!tched about it right away so I deserve a>>>
but on the side note:
how many mins/secs do you guys set your TT to? is 2mins too long? maybe a min is perfect? thanks!
Old Aug 7, 2004
Your HG can go at any boost level...........it is called detonation
