Case breather What are you using.
Old Aug 3, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
What filter are you guys using on the valvecover breather? Ihave looked around town for a filter small enough, but havnt had much luck. Any info would help. Madwheel, civic01vtec what are you guys using?
Old Aug 3, 2004
bic's Avatar
bic
bic is an unknown quantity at this point
K&N makes a good selection of crankcase breather filters you can find online. I dont have a civic but I had to get a filter with a male nipple and use a short piece of hose to raise the filter enough to clear the valve cover. Usually a place like Advance Auto will have 1 or 2 sizes and they are female, so you might have to order it online.
Old Aug 3, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Got mine at a local tuning shop made by 3A Racing. $12
Old Aug 3, 2004
civic01vtec's Avatar
here is the exact one i got from the same place. It is a K&N knockoff....9mm i think.
http://www.2kracing.com/product_info...oducts_id/1858
Old Aug 4, 2004
civicskater's Avatar
Chicks dig my scent
I bought the K&N one, it wasnt cheap but it works perfectly, i dont have oil all over my fuel rail either like i first did when i used a cheap auto zone one
Old Aug 9, 2004
MIAMIVTEC's Avatar
MIAMIVTEC is an unknown quantity at this point
do the breathers really make a difference if u already have an intake??
Old Aug 9, 2004
abmerop18's Avatar
Jam out with your clam out.
get an oil catch can
Old Aug 9, 2004
dezod's Avatar
7thgen Power Maker
Exactly.
Old Aug 9, 2004
MIAMIVTEC's Avatar
was that post 4 me?
Old Aug 9, 2004
MadWheel's Avatar
Premium Boosted Member
I originally bought the K&N filter breather, it worked very well. But an oil can is the way to go. It'll keep the back of your motor a lil cleaner too... I bought a Mororos breather/catch can system.
Old Aug 9, 2004
MIAMIVTEC's Avatar
any pics of ur set-up? any links to where i can buy it online? thannx>> does it work good with the can or better?
Old Aug 9, 2004
mine is a cheapo and i have zero oil drops on my rail. I am happy with it
Old Aug 9, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i have a tube that goes from mine to the intake pipe thats on the intake side of the turbo
Old Aug 9, 2004
Titleist71's Avatar
I'm not positive...but could oil be vacuumed or pumped throught your hose into the turbo?
Old Aug 9, 2004
MIAMIVTEC's Avatar
good point<< isn't that what it does when it's directed to the intake?
so if u have this air breather theres no need to link it to the intake/turbo. because it has it's own filtration system. << correct?
Old Aug 9, 2004
MIAMIVTEC's Avatar
should you guys recomend i should put it on? cuz i've been hearing that it fills up with oil n dirt. also some peepz said they change thier filter twice every thousand miles!!! thats crazy for sumn that doesnt even improve performance or gas mileage.
Old Aug 9, 2004
yes, u need one
I made a post months ago about breather filters and what they do. Search around
EDIT: Here it is......'
http://www.7thgencivic.com/forums/sh...reather+filter
Old Aug 9, 2004
MadWheel's Avatar
Either run a hose from the valve cover to a breather system like the moroso, or if routing back to the turbo, run a line from the valve cover to a breather tank, then the top port of the tank to the intake pipe before the turbo. Those are the best 2 ways to do it.
Old Aug 9, 2004
MadWheel's Avatar
Here's what I bought and here's the only pic I could find of it installed...
ID:	35356   Click image for larger version
Old Aug 9, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
why if ur running turbo cant you just route it into the charge pipes like usual? I read the thread mr dial up posted, but im still wondering.
Old Aug 9, 2004
MadWheel's Avatar
The idea of a breather is for the valve cover to be able to BREATHE. It's not supposed to be pressurized. If you rout it into your charge pipe, you are compressiong the valve cover and could ad unneccessary heat.
Old Aug 9, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
How much is that Moroso oil catch system?? and doesn't greddy make a catch can system too??? thanks
Old Aug 10, 2004
MadWheel's Avatar
$93 on Dezod.com.
Many companies make breather systems.
Old Aug 10, 2004
MIAMIVTEC's Avatar
the only thing i have a question on is the following.
if im n/a, do i need a catch can? what are the chances of the oil spilling out and messing up ur filter and feul rail? is it even likely if i connect it directly for this to happen?
Old Aug 10, 2004
MadWheel's Avatar
No you do not need one. If you are staying NA, might as well rout it to your intake pipe just like stock. It's legal and environment friendly.
Old Aug 10, 2004
Jeff's Avatar
ok I ordered the 9mm breather that civic01vtec said and it looks really small. Im going to have to try to install it tomorrow.
Old Aug 10, 2004
madwheel:makes sense, thanks for the easy explanation!
Old Aug 10, 2004
MadWheel's Avatar
no problem man, glad to help.
Old Aug 10, 2004
took me 2 min........really
you will need a small hose clamp though.....the one they give you won't fit.
Old Aug 11, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Originally Posted by MadWheel
$93 on Dezod.com.
didnt see it on there...street...truehonda...where ya at?
