Other than DENSO, what company for plugs?
Old Jul 26, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
I need to find a place locally where i can get plugs for my civic, because that's all i need now to run my turbo... if i can get these anytime today as soon i get home i'll be boostin, so does NGK make plugs good enough and what is the exact model number i would need for the NGK's running a turbo??? thanks guys... and i did search... just nothing jumped out at me
Old Jul 26, 2004
REDchirp's Avatar
Old Jul 26, 2004
gass03ex's Avatar
gass03ex is an unknown quantity at this point
I would suggest NGK Laser Platinum plugs, part # PZFR6F-11, stock # 3271, with a gap of .044. I would also recommend a new set of NGK wires to match. Turbo's don't necessarily needs "special plugs" just a good set will do fine.
Old Jul 26, 2004
REDchirp's Avatar
first off.. we can't use Spark plug wires, we have a different ignition setup... and secondly do you know of turbo 7thgens using the plugs u suggested???
I was hoping for a knowledgable 7thgen Turbo guru to answer my question... but thanks for the suggestion anywayz!!!
Old Jul 26, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
NGK BCPR7ES plugs, gapped to .32-.34.
Old Jul 26, 2004
REDchirp's Avatar
These work great and last a long time??? and how much am i looking at a piece for these things???
Old Jul 27, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
copper is better for boosted applications
Old Jul 27, 2004
REDchirp's Avatar
why, cause now i'm hearing iridiums ar def. the way to go with boost now....
BootyDo
Jun 21, 2016 03:45 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
CivicsClass101
Jul 9, 2015 11:14 AM
