GT28 or T3 super 60?
Old Jul 22, 2004
HyaBoosta's Avatar
hey guys I am faced with a choice this weekend. I bought an HKS manifold already and was gonna hook it up to a GT28 Garrett turbo. Ultimatley im looking to end up with 275 to 300 whp after all is done. I have an opppertunity to buy a Log style tubular manifold with a t3 flange. so i would hook that up to a t3 super 60. now i know the gt28 is gonna spool faster but im sure that the t3 super 60 is gonna make more HP at the same psi. so the question is what do you guys think? which is gonna best fit my goal?
Old Jul 22, 2004
JDMsicvic's Avatar
JDMsicvic is an unknown quantity at this point
wat all do u plan 2 do to get 275 - 300 whp safetly?
Old Jul 22, 2004
HyaBoosta's Avatar
return fuel system(slp) emanage, RSX injectors, divided down pipe, 3" exhaust, port and polish, arias pistons, crowler rods, upgraded fuel pump, new head gasket...
not off the bat but when all is said and done.I don;t expect 275-300hp off the bat. no way, but what will get me there the most efficient
Old Jul 22, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
hmm...a t3 will forshure have enough flow capacity to make 275whp i think. IM sure the disco potato could do the same, but im not too sure about the gt28. Id say even with all the things you want to do 275WHP is still a super high goal. Many many other things are going to be needed to run that much power on our cars. Tranny/clutch/radiator etc.. will most likely need to be visited to allow for that ammount of power Bottom line i think either turbo would be fine for what you want. The gt28 might be running out of breath, but i dont know forshure. Im just speculating.
Old Jul 22, 2004
HyaBoosta's Avatar
yeah thats what im guessing. of course im gonna upgrade the clutch and flywheel. koyo radiator and FAL fans. But it looks like were not gonna be twins anymore baller. I think im gonna end up goin t3
Old Jul 22, 2004
^ahhh...oh well! We can compare numbers and see what happens!! When do you plan on getting everything?
Old Jul 22, 2004
civicskater's Avatar
Chicks dig my scent
Good luck, for your goals i say the T3. Its going to be interesting seeing the numbers between you two (big baller and hyaboosta). Right now i hope by january i will see 230-250whp, after i dyno at 10psi in sept and upgrade some internals and fuel system. What manifold is it that you are using?
Old Jul 22, 2004
abmerop18's Avatar
Jam out with your clam out.
t3 super 60. thats what im doin at least
Old Jul 22, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
haha, i am going with the t3t04e.....oh, and the SLP return kit comes with the upgraded fuel pump....
Old Jul 23, 2004
its gonna be a long wait untill my car is boosted, so i hope you can wait for numbers! I want to do it right the first time, and i dont wanna have to deal with boost in the winter. Atleast this winter!
JW:decided on you're fuel set-up yet?
Boosta: so you're going to get the manifold that abmerop is gettin'?
Old Jul 23, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
get the T3 Super 60. (just because i am getting it)
Old Jul 23, 2004
cdmx's Avatar
How are the log style manifolds?
Are they ok?
compred to the (tubular?) manifolds are they that much different.
Ill be getting a new job and i think i can start to piece together a turbo kit
sorry back on topic
Old Jul 23, 2004
HyaBoosta's Avatar
baller, im getting a manifold from someone locally in miami. it used to be spdrcrchk's but she didn't use it then she sold it to him but he's not gonna go turbo either. so if it looks good im gonna get it. Plus it's gonna be cheaper in the end cause the t3 super 60 is 595 new and the gt28 is 789
Old Jul 23, 2004
^yah the t3's are alot cheaper than the gt hybrids, just because its older technology i believe. The newer gt turbos have a different design for the turbine and comp wheels. I think it will be close between the two. Like bigger less efficient turbo VS. smaller more efficient turbo! IM pretty sure these are the differences, but i could be wrong! Anyways keep us updated on you're progress. IM really excited to see some other members get boosted!
Old Jul 23, 2004
HyaBoosta's Avatar
if i don;t have everything gathered by sept. then im gonna throw whatever else i need on the credit card and do it.
Old Jul 23, 2004
ahhhsee ur lucky! You dont have to worry about winters and stuff like that! If i were to do mine by sept then id have boost for like 2 months
Old Jul 23, 2004
HyaBoosta's Avatar
It's always hot down here. problem is cooling the car down.
Old Jul 25, 2004
cdmx's Avatar
I think im interested in buying your hks manifold!
CivicMexicano
Engine Swaps
Dec 6, 2004 12:55 PM
