fuel manage
Old Jul 18, 2004
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
fuel manage
this one guy says if im runnin only 5 psi on an ex coupe...he said i would need a fuel management for it..unless if im going high psi like 9 or higher....is that true>???
Old Jul 18, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
**Wouldn't**????
Old Jul 18, 2004
im sorry...yes....he said i *wouldnt* =D =D =D
Old Jul 18, 2004
ImportRacer2123's Avatar
K20 Member
well you should go over and kick him square in the nuts.... That is very unsafe to do. It might be possible but I wouldn't try it.
Old Jul 18, 2004
civic01vtec's Avatar
right now i am running about 5-6 psi with no fuel system b/c my inline fuel pump broke. You can run OBD II cars with no fuel at low boost, but i highly advise against it. The easiest fuel system to do is a fmu......but u can get a more efficent fuel system by converting to a return fuel set-up.
Old Jul 19, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Running 5-6psi is like running a 50 shot of nitrous (with the exception of the lag and torque factor). A VAFC might help in that case, for a temporary solution until you get a decent fuel management system when you bump the boost.
Old Jul 19, 2004
MadWheel's Avatar
Premium Boosted Member
May be so but... the nitrous acts as air AND fuel, not just boost. This is why people can safely drop in 50 shots and go to the track.
Do not run 5-6psi without a fuel system. When my pump was bad (still working but not adding enough) I ran lean at only 3psi. Just get a VAFC2, emanage, or fmu and pump.
Old Jul 19, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Originally Posted by MadWheel
May be so but... the nitrous acts as air AND fuel, not just boost. This is why people can safely drop in 50 shots and go to the track..
That would be assuming the person is utilizing a wet kit. There have been a considerable amount of people who have used dry, including myself.
Anyway, fuel management would be helpful. You can prolly get away with an AFC to start with.
Old Jul 19, 2004
HyaBoosta's Avatar
spdrcrchk what are you using as far as fuel managment? Vafc?
Old Jul 19, 2004
yeah obd II cars are able to supply a efficent amount of fuel for a dry shot.......i wouldn't try it on a 50 shot, but definitely on a 35.
Old Jul 20, 2004
MadWheel's Avatar
This is true lol. Sorry I'm a lil simple minded today. LOOOONG day.
GritzNGravy
Aug 19, 2015 03:03 AM
Klame9420
Aug 13, 2015 06:00 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
