porting intake manifold?
Old Jul 18, 2004
I'm planning to get my TB bored out, so I was wondering if it's possible for me to port match the IM where they bolt together. I think the opening and entire manifold is plastic, but would it be possible to use a dremel to make the opening larger? I think it's only like 1mm bigger bore.
Old Jul 18, 2004
civic01vtec's Avatar
I read somewhere that port matching the TB and IM isn't a good idea. I'll have to look and see if i can find that.
Old Jul 18, 2004
Okay thanks. Cause if I get the TB ported, then what's the point if the IM is still smaller? I guess it would still help maybe.
Old Jul 19, 2004
orso's Avatar
orso is an unknown quantity at this point
^^^ more is not always neccessarily better. just food for thought
Old Jul 19, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if you're turbo, go for it ... ;D
Old Jul 19, 2004
Hmmm, still no answer. I was asking about porting the intake manifold. Anyone actually done it?
Old Jul 19, 2004
dezod's Avatar
7thgen Power Maker
Remember, rigid intake imports are good. This creates more air turbeulence, which creates better combustability.
Old Jul 19, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I guess it's time to get the ol' knife and start scraping away
jk ... but I dunno if doing it to a plastic im would be a good idea since small plastic chips might get sucked into the engine ...
Old Jul 19, 2004
Haha yeah. I don't like the idea of plastic going into the manifold. I guess I could try a dremel if I somehow tape off the bottom part. Hmmm. I don't know what dezod is talking about with intake imports But I'm referring to where the TB and IM meet.
Old Jul 20, 2004
MadWheel's Avatar
Premium Boosted Member
I think he's just tired and meant intake ports.
Old Jul 20, 2004
djmota's Avatar
I would suggest taking the intake manifold out to do this. There will be no risk of getting the bad stuff in your engine. 1mm should not be a problem at the base. A dremel would be the best tool for the job.
Old Jul 20, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by MadWheel
I think he's just tired....
ALWAYS A TRUTH.
Old Jul 20, 2004
Heh. No way am I taking off the IM. So I guess it's dremel time with an extension cord. It's also gonna be hard to port match without making some kind of outline. Oh well, I'll probably have a diy for you when I do it.
Old Jul 20, 2004
allmotor's Avatar
nor cal 7thgens
i think if u did it u would get some gains didnt dh racings tb lose power?
Old Jul 20, 2004
I'm expecting gains, hopefully by letting in more air than normal. This will help with the ported head setup. The DH one will probably lose power since it's so huge. The pro I'm sending to is maybe gonna bore mine 1mm. So from 59mm to 60mm, which is pretty good all around. Comes with new brass valve and all, plus I don't lose any sensors/cruise.
Old Jul 20, 2004
djmota's Avatar
who are you sending it to?
Old Jul 20, 2004
www.maxbore.com
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
