Press-Bent Piping Question!!!
Old Jul 14, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Talking Press-Bent Piping Question!!!
Can i have some custom Press bent Piping incorparated in to make my IC piping work for right now??? is it gonna cause me problems if i'm only using this for a lil bit and I'm only planning on running 5 psi? lemme know... cause i need to go to teh exhaust guy tomorrow... thanks
Old Jul 14, 2004
REDchirp's Avatar
^^^ Important question at hand here guys... lemme know
Old Jul 15, 2004
REDchirp's Avatar
TTT guys.. i'm an impatient bastard
Old Jul 15, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i cant see press bent causing any problems, although its not ideal at all.. find an exhaust guy with a mandrel bender if possible.. or just buy pre-bent pipes online.. and cut them to fit
Old Jul 15, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
there is some theory that you loose1/4 to1/2 lb for each crush bend or something like that because it isn't mandrel and smooth air flow. For what you and i are running, A little here and there will be fine.I dont think i will og pass 10psi if even that far.
IMO.. I personally am gonna have one because of my new FMIC and i don't feel like sending out for (1) new bend so all my pipes but one will be mandrel.
Old Jul 15, 2004
REDchirp's Avatar
Yea... i'm using all mandrel bent pipe except for the one i need pressbent is going from the drivers side of the IC over the top of it, then back down and onto the turbo... and for all who didn't get that.... ( THE CHARGE INLET PIPE)
Old Jul 15, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Use it temporarily then switch to mandrel when you can. JC Whitney sells 180 ubends.
Old Jul 15, 2004
REDchirp's Avatar
I have an extra Mandrel bent U-bend... but it's almost too big... like too wide of a u-bend if you understand what i'm saying...
Old Jul 15, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
You mean the degree of the bend is not right. Well.....I wouldn't ever recommend crush bends. Not even if u were goin n/a. But if you KNOW you're gonna be able to replace it later, it's not gonna kill ur car. Besides, running 5psi you wont be making much power anyway.
Old Jul 15, 2004
REDchirp's Avatar
ya... it wouldn't be for very long at all... but at that rate is that even worth it???
Old Jul 15, 2004
SpdRcrChk's Avatar
BOOST JUNKY
its worth it to have mandrel...not worth it to have crushed. It's just a general rule. Ask anyone. Unless u don't care about performance much. then it's w/e.
Old Jul 15, 2004
REDchirp's Avatar
can a shop mandrel bend one pipe that goes from my drivers side of the IC over the top of the IC and then back to the Turbo outlet, ( the Inlet charge pipe)... can a mandrel bender make that all into one pipe??? and how much do you think that would cost me?
Old Jul 15, 2004
Your Parts Guy
Sure it's definitely possible but I'm not sure what they'd charge. If it were me I'd buy the piping myself and just take it to them to weld after I cut it up.
martinsmartin
Aug 15, 2015 07:34 PM
PierrePierre
Aug 12, 2015 02:42 PM
Joethornton
Aug 7, 2015 09:53 AM
CivicsClass101
Jul 9, 2015 11:14 AM
Causemo
Jul 5, 2015 06:42 AM
