Better cooling fans/radiator?
Old Sep 28, 2004
  #31
HyaBoosta's Avatar
got any pics of the radiator installed. did everything bolt right up? how much did it cool down?
Old Sep 28, 2004
  #32
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I had the same overheting problem while ideling, and after I drived it cooled.
It was without turbo, and it went on for 2 days.
The oil and antifresse didn't mixed but after removing the head we noticed very small leaks on piston one and three.
A good way to test is to start the car while cold, with the radiator cap off, accelerate hard a few time to about 4000RPM and if the coolant shuts out or circulates in the radiator viguorously it means that the engine compression is leaking through the coolant engine compartment.
It may be only small enough that the coolant doesn't get into the oil.
Also in my case I noticed that the antifreze reservoir overflowed only while driving hard.
I will have to upgarde to a new radiator soon and I wonder how much thicker a Koyo radiator is compared to stock.
And how will it fit with a custom turbo on it.
Old Sep 28, 2004
  #33
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Hector I have a Koyo in stock it's yours if you want it, PM me.
Old Sep 28, 2004
  #34
Your Parts Guy
Originally Posted by JetBlu01
I just installed a Koyo radiator...it cured my overheating problems.... SLP (streetlevelperformance)
Glad to hear it Cliff
Old Sep 28, 2004
  #35
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Supermex, that was not my problem, my problem was there was absolutely no airflow at a stop with the fans running, I tested that by putting my hand behind the radiator... I felt nothing.
Put the better fans on, now my hand moves back about 2 inches from the air flow when they're on, and no more overheating.
Old Sep 28, 2004
  #36
First to spool
I'll put up pics sometime this weekend. Had to cut a 1" section of the shroud to fit around the bottom coolant hose. These fans are NOT a bolt on fan designed for our engine, FAL does not have an 01+ Civic application. I used the 01+ Ford Focus fans, and used the radiator fan mounts that are basically cushioned zipties that go through the radiator. They hold perfectly, and I'm not going to waste time fabricating mount adapters that are not needed.
Cooled down a lot, now when the fans come on at idle, my coolant temp according to my datalogger drops 10 degrees celsius in 15 seconds. Seriously. That's about 10 times faster than the stock fans could even before the car was turbocharged. My a/c is a LOOOOOOOOOT colder now too.
Old Sep 29, 2004
  #37
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
here are a few pics before I installed it...it would be be pointless to try to take pics of it installed b/c u cant see it from my bumper cover
Name:	Koyo Radiator #1.JPG
ID:	39088   Click image for larger version
Name:	Koyo Radiator #2.JPG
ID:	39089   Click image for larger version
Name:	Koyo Radiator #3.JPG
ID:	39090   Click image for larger version
Name:	Koyo Radiator #4.JPG
Old Sep 29, 2004
  #38
JetBlu01's Avatar
New Member
here's a pic of my BUSTED OEM radiator...u can see where it was leaking from...soon as your pour coolant in, it would come out right there at the bottom where the rubber part is separated kinda....
Name:	Busted Radiator #1.JPG
Old Sep 29, 2004
  #39
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Forced induction usually strains the cooling system a lot more. Both in the added restriction and in the added heat inside the compartment.
Things that usually help are lower thermostat and fan switch (keeps coolant flowing more and turns the fans on earlier). A bigger radiator, as the OEM is not usually enough and more coolant and more fins are always better. And high flow fans do wonders during idle or traffic.
A really good reason to add either a oil temp or water temp gauge to the mix. The stock gauge is little more than an idiot light, meaning it only goes up when it is almost too late. Seems customers always complained that the stock gauge jumped around too much. So manufactureres put in a circuit that limits the stock gauges movement.
Old Sep 29, 2004
  #40
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
The past few days ive also had a issue with my car keeping cool. When i would sit idle at a stop light or something the car would over heat. When i drive then it cools down, like others on the board. So today i drain the coolant, add fresh water and antifreeze. Take it for a drive and it is still overheating while idle. So the next thing i do is go get a new thermostat. That doesnt work either the car still runs hot at idle. The fans come on like normal, so i didnt think that that would be a problem. Car still over heating at idle. So the next thing i did was unpluged the thermostat sensor, and put a piece of wire on the 2 plug contacts so that the fans would stay on all the time. Then i drove around for like 30 mins to an hour letting the car idle for 5 mins or more at times and the car never overheated while idle. So im guessing that the stock fans are insuficient like riceburnrex said. Until i can get some new fans, ill just keep them running all the time.
Old Sep 29, 2004
  #41
First to spool
Sodjazero, one thing you can do that may be a little better than just using the piece of wire is to get some relays and switches (about $5 worth) and make a fan-on switch for when you need it. You can then turn them off when it's cool outside and you're not overheating, and when you're running on the highway. If you get the right relays, the stock ECU can still control the fans, or you can have them come on whenever you want. I can show you how to wire that up on Sunday and what relays to use if you want.
If you're interested, we may still have some of the FAL fans, same type that I used. I'll check and see and if we still have some, check on a price for ya.
Old Sep 29, 2004
  #42
SODJAZERO's Avatar
Anything that will help, thanks. But it looks like i spoke too soon. I went to go pic up money from my friend, I was stitting at taco bell, the next thing i know the it starting heating up after like 7mins. Slower than than the normal overheating phases but it does overheat still. This is really starting to pi$$ me off. Any ideas? But i def am interested in fal fans, what ever i can use to keep this thing from doing this.
Old Sep 29, 2004
  #43
First to spool
You need better fans or a better radiator... that's about all you can do except remove your intercooler.
The FAL fans will definately fix the problem, I'll check into price and availability tomorrow for you.
Old Sep 30, 2004
  #44
SODJAZERO's Avatar
Thanks man, ill be waiting!
Old Sep 30, 2004
  #45
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
didnt feel like reading the whole thread... so do they have those really thin fans for our cars yet and who has em and makes em
Old Sep 30, 2004
  #46
First to spool
Lazyass...
In short, FAL does not make some directly for our cars but there is an application that fits with minimal modification.
Old Sep 30, 2004
  #47
Lazyass...
right now i am.. lol...
Old Oct 1, 2004
  #48
supermex's Avatar
Does anyone has a stock radiator I could use for 2 weeks? even if is busted.
I have a new project I'll like to try.
I'll pay for all shipping.
Old Oct 2, 2004
  #49
JetBlu01's Avatar
New Member
u want someone to GIVE u the OEM radiator or u just wanna BORROW one...
Old Oct 2, 2004
  #50
supermex's Avatar
I just need to borrow it for 2-3 weeks.
You'll get it back in one piece may be even fixed.
PM me
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
juicetayne
Sep 30, 2015 11:02 AM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
