VAFC Hack w/ RSX Injectorers?
Old Jul 2, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Anyone have any thoughts/insight/ideas on why this would wouldn't work?
Old Jul 2, 2004
opto_isolator's Avatar
Might work since the rsx injectors aren't that much larger than stock....
Old Jul 2, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
im tyrin the SAFC with the RSX injectors
safc hook up and still waitin on the injectors
Old Jul 2, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
doesnt the safc disrupt ignition timing tho making if worse for boost?
Old Jul 2, 2004
I thought safc only controls air/fuel?
Old Jul 2, 2004
it's a piggy back fuel system
it tells the ECU one thing when actually it's doing some thing else.
i.g. it will tell the ECU that the car is running lean when actually everything is running fine so the ecu will add more fuel to acccomodate all the extra forced air in the engine that the ECu doesn't even know is there..unless you dont have check valves or a missing link and MAP sensor starts seeing boost/pressure
shouldn't be any different from all the AFC hacks i've seen with 450's and a resistor box except the RSX are saturated and dont need a resistor box.
the only difference betweent he VAFC and the SAFC is that the VAFC lets you adjust the VTEC engagement.
Old Jul 2, 2004
Technically it does. However, you must remember that the MAP sensor is essentially a load sensor for the car. The ECU bases timing on (among other things), the MAP sensor. When you start to play around with the MAP voltage, it changes timing....which is why the Emanage is a better option - you can add more timing back in to compensate....
metalviper
Jan 15, 2008 01:04 AM
ktenhuisen
Engine Swaps
May 31, 2006 08:39 PM
Barney
Engine Swaps
19
Apr 29, 2005 05:01 PM
navyedoc
Engine Swaps
Nov 25, 2004 07:46 PM
d17lpower03
Engine Swaps
Aug 4, 2004 10:12 AM
