colder plugs for milled head?
Old Jun 28, 2004
Is it necessary to change to colder spark plugs with the increased compression. All over I'm reading that too hot a plug causes engine damage, while too cold just fouls the plug. So is it safer to get a colder one?
Also, I'm thinking about going back to regular copper plugs instead of iridium. Thanks for any help.
Old Jun 29, 2004
ExospeedRacing's Avatar
ExospeedRacing is an unknown quantity at this point
iridium is overrated. Im sure it works, but for the price to pay for something you have to keep on replacing, i'd rather get the standard NGKs.
We use regular NGKs on our Race cars. Plugs are changed almost every run so it gets pricey. but even on street cars. I'd rather change the plugs more often than run an expensive plug and not change for a few thousand miles.
Old Jun 29, 2004
So should I use a colder plug for the milled head (higher compression)?
Old Jun 29, 2004
civic01vtec's Avatar
honestly, you won't need to. The slight change in compression won't lead to detonation from the stock plugs. Just stay with the same heat range as stock.
Old Jun 30, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
can you gap to a bigger size and run colder?
Stock gap recomended .040 stock civic D17
can I go 0.43 on the same engine?
Old Jun 30, 2004
I was wondering the same thing. I'm taking out my iridiums and just trying some regular NGK v-power plugs to see if it helps the rough idle. From what I've read, those iridium and platinum aren't all that great. I think using anything but regular copper for turbo apps is also a big nono. I'll let you guys know the difference between the regular ones and my old iridiums later.
thana
Jun 15, 2020 07:05 PM
159
Jul 5, 2015 09:54 PM
danace99
23
Jun 28, 2015 08:49 AM
fabfive16
May 3, 2015 09:26 PM
StLVtec
Dec 26, 2001 08:32 PM
