Help! What goes here?
Old Jun 17, 2004
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
What plugs into that little hole there?
Old Jun 17, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
It's for your stash when the cops come.
Old Jun 17, 2004
NoSpleeny's Avatar
heh!
Seriously
Old Jun 17, 2004
opto_isolator's Avatar
I just went to home depot and bought a bolt and teflon paste to plug it. Its basically a vacuum / boost reference port.....
The only issue with using it however is that you may get a pressure drop from your piping and intercooler - which means your reading wouldn't be as accurate as if you tapped the vac line off of the intake manifold......
Old Jun 17, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
isn't there suppose to be a fitting with a hose there that hooks up to the internal wastegate?
Old Jun 17, 2004
NoSpleeny's Avatar
Where do you hook up the manual boost controller?
Old Jun 17, 2004
in between that line i believe
between the wastegate and where the fitting is suppose to be
Old Jun 17, 2004
NoSpleeny's Avatar
I doubt that tho...
The wastegate hooks up on the exhaust side of the turbocharger itself.. not the intake side.
Old Jun 17, 2004
the WASTEGATE ACUATOR
Old Jun 17, 2004
NoSpleeny's Avatar
Yep. I know. But where does the boost controller sit? Does it sit on the vacuum line from the wastegate?
Old Jun 17, 2004
he has an external but still a wastegate
from there it is "T'd" in with the Turbo XS MBC and the Line going up to the manifold(vacuum line)
Old Jun 17, 2004
click on Vacumm hose and T fittings
http://www.beesandgoats.com/boostfaq...urbo.html#Tfit
