Fuel set-up questions...
Old Jun 17, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok so as my turbo project comes closer and closer to completion, I am wondering what kind of fuel set-up I sould run.
I am probaly going to end up getting a T3 Super 60 Turbo.
Now I know a lot of this has been covered, but I am trying to get everything together so...
How much MAX boost can I run on a well-done fuel set-up, dyno-tuned...without running into problems?
How much would you recommend for a turbo set-up without any fuel upgrades?
Right now I have a VAFC2, would my stock injectors do enough for about 6-8 PSI? Or would I have to upgrade the injectors?
Or should I just sell the VAFC2 and get a Greddy Profec E? Is it worth the money?
Or should I just get a FMU?
Should I replace the injectors? Or should I do a return fuel system?
Lol, so many options...I need help!
Old Jun 17, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
You will be fine at 8 PSI on stock injectors. You can convert to a return-style fuel system or run an inline pump and fmu. How serious are you? If you are really serious and want to fully build the block then wait for the AEM EMS. If you just want something quick to help you get boosted I recommend the GReddy e-Manage. It is inexpensive and allows you to retard ignition timing, which is very valuable with forced induction. Plus, if you like the Profec e-01 it can be used in conjuntion with the e-Manage.
Old Jun 17, 2004
dezod's Avatar
7thgen Power Maker
AEM EMS is going to be a super nice piece. Self teaching and all, but WAY overpriced! GReddy E-Manage is a solid piece for the price. Quite powerful and functional for the cost.
Just remember our stock injectors are tuned from Honda @ a 85% duty cycle. Any additonal strain on these will be bad for them.
Old Jun 17, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
i remember reading that
so if that's the case i still dont understand what the SF kit is doing
just adding an inline pump?
Old Jun 17, 2004
Havok2k1's Avatar
Wicked Pissah Admin
The pump is there to supply the increase in FP from the FMU.....
Old Jun 19, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Who makes the pump? Walbro? How many lph?
Old Jun 19, 2004
it's a nice thought but someting bound to happen on a car that was factory turbo'd
i plan on gettin a walboro in the future but not in any rush at the moment
same thing with injectors. I'll b fine with 5 daily until i get some internals.
i wann get another engine but i know i cant have that sitting in my parents garage..maybe one of my frineds thou
they alrady got plenty of **** just lying around
Old Jun 22, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
so what are all the options for fuel tuning. Ive got most of the other stuff planned out for my kit, but fuel is by far the most confusing. For a custom set-up what can be used, and how can you tune it?
edit: what does the vortech FMU? I know it increases fuel pressure, but what else is needed to run it?
Old Jun 22, 2004
Your Parts Guy
You will need an inline fuel pump to deliver more fuel.
Old Jun 22, 2004
^so the vortech controls the flow of fuel, and the fuel pump actually delivers it? IS it possible to tune both of these without any other components?
Old Jun 23, 2004
HyaBoosta's Avatar
I heard that the ignition timing function was having trouble working on our cars? is this true? anyone running the emange using the ignition timing?
Old Jun 24, 2004
civic01vtec's Avatar
the vortech is hooked up to a vaccuum line.........it reads boost pressure. There are different types of ratios............8:1, 10:1 and 12:1.
For every 1 psi of boost the inline pump will increase fuel pressure by 10 psi or whatever the ratio of ur fmu is.
Old Jun 24, 2004
i highly suggest converting to a return set up..........u will need a fuel pump, fpr, and you will need to modify ur fuel rail. Stock injectors will be fine if u stay under 10psi.
Also, your vafc2 will work fine but you will definitely need to get it dyno tuned ASAP.
Old Jun 24, 2004
^^ahh i gotcha...that seems like a pretty efficient set-up, except if you're pump breaks . So what is wrong with the inline pump set-up? More stress on the stock injectors? We need an aftermarket fuel rail that allows a return line, and injectors. So why is a return line better?
cwisenbaker06
Aug 19, 2015 04:29 PM
GritzNGravy
Aug 19, 2015 03:03 AM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
