Oil pan pictures??
Old Jun 15, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
Thumbs up Oil pan pictures??
Anyone need any pictures?
I gotta pull mine back off tonight( dont ask why) so I'm just offering up
be back on in a hour
Old Jun 15, 2004
havocErnie's Avatar
havocErnie is an unknown quantity at this point
i would be interested in some. I need to install a temp gauge and need to locate a good side to drill the whole.
Old Jun 15, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I would like to have a few better pics of the oil sender, actually. still want to see how the manifold gets in the way of the sensor (why you have an elbow attachment at the end of your tuner toys fitting)
I was also thinking about using stainless steel fittings though, maybe those will hold up fine. I'm guessing in every case where they broke, they were brass or some other weak fittings.
Old Jun 15, 2004
the pan is off now
i have the elbow there because when you try to screw the sensor into the back on the tuner toys fitting there just isn't enough room. It's because of the way our intake manifold ar designed. They dont go straight back like older models, they come down like a bubble.
be takin picture in a minute and have them up later
Old Jun 15, 2004
not on my computer so ths is Micro paint i had to work with
diminsions arem't exact but you get the idea
you have to put a bend there if you want to hook you sensor back up
Old Jun 16, 2004
well the pan is back on now and sealed.
the pic you look for Mex i tried but couldn't get because the Oil filter kept getting in the way and when i used the flash it kept reflecting off something. I'm sure i'll be back under my car soon so i'll keep you in mind, probably on the next oil change.
Old Jun 16, 2004
Mex's Avatar
Mex
what kind of gasket did you use when attaching the oil pan?
Old Jun 16, 2004
Permatex Ultra Black Hi-temp RTV silcone gasket maker-598B
like 3 or 4 bucks at Autozone
theteju
Aug 5, 2015 06:59 PM
silentz
Jul 9, 2015 08:16 PM
jzhartman
Jul 9, 2015 04:56 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
Causemo
Jul 5, 2015 06:42 AM
